[Qgis-user] QGIS Error reading database file from: ~/.qgis/qgis.db
William Kyngesburye woklist at kyngchaos.com
Tue May 21 07:22:38 PDT 2013
do you have the system's Gatekeeper on? (System Prefs-Security-General-Allow applications, either of first 2 options)  Try it after setting that to Anywhere.
Something changed in your system or user environment recently (if it was working previously)?  Or maybe a new QGIS plugin you installed?  Try removing recently-installed plugins.
Try creating a new user and run QGIS in that new login.
On May 21, 2013, at 8:57 AM, Julian Bogdani wrote:
> Hello all,
> I'm having a strange error on MacOS X Mountaint Lion (10.8.3) witha latest QGIS 1.8.0/2 (downloaded from KyngChaos repo).
> I have a big project on which I've been working for long time, but suddenly I'm having some problems on loading new data, both rasters and shapefiles.
> Trying to loaf layers using Menu, QGIS simply craches. Dragging the shapefile to the layers TOC I'having the following error: Error reading database file from:
> /Applications/QGIS.app/Contents/MacOS/../Resources/resources/srs.db
> Because of this the projection selector will not work...
> and then this:
> /Users/Jack/.qgis//qgis.db
> Loading the same shapefile on a new project works perfectly. I tried to create a new project and the error came back.
> The hole project, does work correctly on another MacOS (10.6.8) and on Win PC.
> I've also tried to remove QGIS and reinstall it; delete user and preferences folders (following this guide: http://press.underdiverwaterman.com/clean-install-of-qgis-in-osx/) but my problem is still there.
> Any help will be much appreciated,
> thank you
> Julian Bogdani
> jbogdani at gmail.com
> http://bradypus.net
> Qgis-user mailing list
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"I ache, therefore I am.  Or in my case - I am, therefore I ache."
- Marvin
