[Qgis-user] QGIS Error reading database file from: ~/.qgis/qgis.db
Julian Bogdani jbogdani at gmail.com
Tue May 21 07:45:24 PDT 2013
Hello,
system's Gatekeeper is already set to Anywhere and I've not made any recent system update.
I've completely removed the previous QGis installation, removed all installed plugins and user preferences / cache.
I'll try to create the new user and check if this will solve the problem.
Thank you
Julian Bogdani
http://bradypus.net
On 21 May 2013, at 16:22 , William Kyngesburye wrote:
> do you have the system's Gatekeeper on? (System Prefs-Security-General-Allow applications, either of first 2 options)  Try it after setting that to Anywhere.
> Something changed in your system or user environment recently (if it was working previously)?  Or maybe a new QGIS plugin you installed?  Try removing recently-installed plugins.
> Try creating a new user and run QGIS in that new login.
> On May 21, 2013, at 8:57 AM, Julian Bogdani wrote:
>> Hello all,
>> I'm having a strange error on MacOS X Mountaint Lion (10.8.3) witha latest QGIS 1.8.0/2 (downloaded from KyngChaos repo).
>> I have a big project on which I've been working for long time, but suddenly I'm having some problems on loading new data, both rasters and shapefiles.
>> Trying to loaf layers using Menu, QGIS simply craches. Dragging the shapefile to the layers TOC I'having the following error: Error reading database file from:
>> /Applications/QGIS.app/Contents/MacOS/../Resources/resources/srs.db
>> Because of this the projection selector will not work...
>> and then this:
>> /Users/Jack/.qgis//qgis.db
>> Loading the same shapefile on a new project works perfectly. I tried to create a new project and the error came back.
>> The hole project, does work correctly on another MacOS (10.6.8) and on Win PC.
>> I've also tried to remove QGIS and reinstall it; delete user and preferences folders (following this guide: http://press.underdiverwaterman.com/clean-install-of-qgis-in-osx/) but my problem is still there.
>> Any help will be much appreciated,
>> thank you
>> Julian Bogdani
>> http://bradypus.net
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> "I ache, therefore I am.  Or in my case - I am, therefore I ache."
> - Marvin
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130521/87d9cc34/attachment.html>
