[Qgis-user] Add XY data via XY tool plugin, how to install
Ardkham Banjong vet018 at yahoo.com
Tue May 21 19:42:09 PDT 2013
Banjong Ardkham, D.V.M
Phayao Provincial Livestock Office, Thailand
Department of Livestock Development
Phahonyothin road, Muang District, Phayao province.
Mobile Phone-Thailand: +6608-6114-6377
Email: vet018 at yahoo.com
 From: "qgis-user-request at lists.osgeo.org" <qgis-user-request at lists.osgeo.org>
To: qgis-user at lists.osgeo.org
Sent: Tuesday, May 21, 2013 10:31 PM
Subject: Qgis-user Digest, Vol 87, Issue 51
Send Qgis-user mailing list submissions to
To subscribe or unsubscribe via the World Wide Web, visit
    http://lists.osgeo.org/mailman/listinfo/qgis-user
or, via email, send a message with subject or body 'help' to
You can reach the person managing the list at
    qgis-user-owner at lists.osgeo.org
When replying, please edit your Subject line so it is more specific
than "Re: Contents of Qgis-user digest..."
Today's Topics:
   1. Re: QGIS Error reading database file from:    ~/.qgis/qgis.db
      (Julian Bogdani)
   2. Add XY data (AGBO Yawo S?gb?aya)
   3. Re: Add XY data (Raymond Nijssen)
   4. Re: Add XY data (Ing. Juan M. Bernales)
Message: 1
Date: Tue, 21 May 2013 16:45:24 +0200
To: William Kyngesburye <kyngchaos at kyngchaos.com>
Cc: qgis-user <qgis-user at lists.osgeo.org>
Subject: Re: [Qgis-user] QGIS Error reading database file from:
    ~/.qgis/qgis.db
Message-ID: <2719C47C-3BAA-45BD-B944-A3B7CEDEA6CF at gmail.com>
Content-Type: text/plain; charset="us-ascii"
Hello,
system's Gatekeeper is already set to Anywhere and I've not made any recent system update.
I've completely removed the previous QGis installation, removed all installed plugins and user preferences / cache.
I'll try to create the new user and check if this will solve the problem.
Thank you
Julian Bogdani
jbogdani at gmail.com
http://bradypus.net
On 21 May 2013, at 16:22 , William Kyngesburye wrote:
> do you have the system's Gatekeeper on? (System Prefs-Security-General-Allow applications, either of first 2 options)  Try it after setting that to Anywhere.
> Something changed in your system or user environment recently (if it was working previously)?  Or maybe a new QGIS plugin you installed?  Try removing recently-installed plugins.
> Try creating a new user and run QGIS in that new login.
> On May 21, 2013, at 8:57 AM, Julian Bogdani wrote:
>> Hello all,
>> I'm having a strange error on MacOS X Mountaint Lion (10.8.3) witha latest QGIS 1.8.0/2 (downloaded from KyngChaos repo).
>> I have a big project on which I've been working for long time, but suddenly I'm having some problems on loading new data, both rasters and shapefiles.
>> Trying to loaf layers using Menu, QGIS simply craches. Dragging the shapefile to the layers TOC I'having the following error: Error reading database file from:
>> /Applications/QGIS.app/Contents/MacOS/../Resources/resources/srs.db
>> Because of this the projection selector will not work...
>> and then this:
>> /Users/Jack/.qgis//qgis.db
>> Loading the same shapefile on a new project works perfectly. I tried to create a new project and the error came back.
>> The hole project, does work correctly on another MacOS (10.6.8) and on Win PC.
>> I've also tried to remove QGIS and reinstall it; delete user and preferences folders (following this guide: http://press.underdiverwaterman.com/clean-install-of-qgis-in-osx/) but my problem is still there.
>> Any help will be much appreciated,
>> thank you
>> Julian Bogdani
>> http://bradypus.net
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> "I ache, therefore I am.  Or in my case - I am, therefore I ache."
> - Marvin
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130521/87d9cc34/attachment-0001.html>
Message: 2
Date: Tue, 21 May 2013 14:58:43 +0000
To: Qgis-user at lists.osgeo.org
Subject: [Qgis-user] Add XY data
Message-ID:
    <CAO7EOpC6JMkySMw+diUGpFZr2LQuxgvD8Gqo4BdGkF97HgWVYg at mail.gmail.com>
Content-Type: text/plain; charset="iso-8859-1"
Dear
do you mind show me howto add XY data in Map in QGIS? Thanks.
*Agbo Yawo S?gb?aya*
G?ologue Explorateur
Chef de Dvision Prospection Mini?re
Direction des Recherches G?ologiques et Mini?res (DRGM) de la Direction
G?n?rale des Mines et de la G?ologie (DGMG)
06 Avenue Sarakawa, BP: 356 Lom?-Togo,
                                   Tel Service :+22822213001; Fax :
+22822213193,                                      Mobile : +22890396980 Skype:
segbeaya74;                                                        E-mail:*
agboyawo at yahoo.fr* ou yawo74 at hotmail.fr
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130521/ff4c2944/attachment-0001.html>
Message: 3
Date: Tue, 21 May 2013 17:18:15 +0200
Subject: Re: [Qgis-user] Add XY data
Message-ID: <519B9037.4040601 at terglobo.nl>
Content-Type: text/plain; charset="iso-8859-1"; Format="flowed"
check this:
http://www.gistutor.com/quantum-gis/19-beginner-quantum-gis-tutorials/59-how-to-create-a-shapefile-from-xy-data-using-qgis.html
On 05/21/2013 04:58 PM, AGBO Yawo S?gb?aya wrote:
> Dear
> Direction G?n?rale des Mines et de la G?ologie (DGMG)
> 06 Avenue Sarakawa, BP: 356 Lom?-Togo, Tel Service:+22822213001; Fax :
> segbeaya74;E-mail:_agboyawo at yahoo.fr_ou yawo74 at hotmail.fr
> <mailto:yawo74 at hotmail.fr>
Terglobo
Amp?restraat 110
5223 CT 's-Hertogenbosch
06-25314983
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130521/ab0fe811/attachment-0001.html>
Message: 4
Date: Tue, 21 May 2013 10:25:58 -0500
From: "Ing. Juan M. Bernales" <jm_bernales at hotmail.com>
To: AGBO Yawo S?gb?aya <perdejumo at gmail.com>,    "QGIS"
Message-ID: <COL126-DS16438DC3A65DEAD1FB86BD97A80 at phx.gbl>
Or you can use the XYTOOLS also, it suports old excel files.
Sent: Tuesday, May 21, 2013 9:58 AM
Dear
Agbo Yawo S?gb?aya
Direction des Recherches G?ologiques et Mini?res (DRGM) de la Direction G?n?rale des Mines et de la G?ologie (DGMG)
06 Avenue Sarakawa, BP: 356 Lom?-Togo,        Tel Service :+22822213001; Fax : +22822213193,                                      Mobile : +22890396980 Skype: segbeaya74;                                                        E-mail: agboyawo at yahoo.fr ou yawo74 at hotmail.fr
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130521/cdc934db/attachment.html>
End of Qgis-user Digest, Vol 87, Issue 51
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130521/d6e1ef4b/attachment.html>
