[Qgis-user] Recognition of SRS in MapInfo-Files
Bo Victor Thomsen bo.victor.thomsen at gmail.com
Fri May 24 23:05:55 PDT 2013
Andreas -
The problem is twofold -
  * QGIS (or rather the underlying ogr library)  has a bug in some cases
    when determining the projection in TAB files (i.e EPSG:25832) . This
    bug is solved in version 1.10 of GDAL.
  * Your editing of QGIS CRS parameter database  won't give you the
    wanted result, because when QGIS try to find the projection of a tab
    dataset it (probably) goes like this:
    a) find MapInfo specific projection parameters in tab file,
    b) convert these to the equivalent  proj4 definition and
    c) do a reverse lookup to find the EPSG code
    QGIS never will never find your edited CRS parameters
As you suggested, a solution to this problem could be to let QGIS
override the "build-in" projection in a tab file with a .qpj companion
file just like the case with shape files. (Doesn't it do this already ?)
I suggest you make a feature request on the QGIS bugtracker
Regards
Bo Victor Thomsen
Aestas-GIS
Denmark
Den 25-05-2013 01:57, Fischer, Andreas skrev:
> Re: [Qgis-user] Recognition of SRS in MapInfo-Files
> Dear Community,
> I just hadanidea:
> If a shape fileis created withQGIS a .qpjfile is createdas well. This
> file is used always when it isexisting.QGISdoesn't care of settings in
> .prj file and just uses the definitions in .qpj file.That seems to be
> almost perfect, becauseallchanges of the build in SRS definitions are
> consideredin that qpj file.Unfortunately this file is without usefor
> MapInfo TAB files.
> Wouldn't it be possibleto make this goingonwith other formats as well?
> Thismight be a solution that does not care about ogrsettingsin first
> place. If ogr works fine nobody has needs for .qpj files. But in other
> cases,everyonecould determinethe parameters to use. If these are
> defined exactly like build in SRS matching should not be a problem.
> Best regards
> Andreas
> Mit freundlichen Grüßen
> Im Auftrag
> Andreas Fischer
> Sachgebietsleiter
> Kreis Unna - Der Landrat
> Zentrale Datenverarbeitung
> Sachgebiet DV-Organisation
> Friedrich-Ebert-Straße 17
> 59425 Unna
> Fon 02 3 03 27-44 16
> Fax 0 23 03 27-28 96
> _andreas.fischer at kreis-unna.de_<mailto:andreas.fischer at kreis-unna.de>
> _www.kreis-unna.de_<http://www.kreis-unna.de>
> Denken Sie an die Umwelt. Pruefen Sie deshalb bitte,
> ob der Ausdruck dieser E-Mail wirklich notwendig ist.
> Diese E-Mail wurde beim Ausgang auf Viren geprueft. Wegen der
> potentiellen Gefahr auf den Uebertragungswegen wird zu einer
> Vireneingangskontrolle geraten. Eine Haftung für Virenfreiheit
> wird ausgeschlossen.
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130525/aadb2acd/attachment.html>
