[Qgis-user] Python Error
Luis M. Ruiz E.
geografoaplicado at gmail.com
Wed May 29 04:56:31 PDT 2013
Hi Comunity¡¡¡¡¡¡¡¡¡¡
i have a real big problem with python in ubuntu 13.04.
i installed qgis since a 3 months, and no problems, but, when i want to use
the open layers plugin, qgis crash, close unspectly. tired with the
situation, i uninstall the program, but, when i try to re install, show me
the following message:
the python support is enabled:
No se pudo cargar PyQGIS.
El soporte para Python estará deshabilitado.
File "", line 1, in
RuntimeError: the sip module implements API v6.0 but the qgis.core
module requires API v5.0
Versión de Python:
2.6.4rc1 (r264rc1:75270, Oct 13 2009, 17:19:27)
[GCC 4.4.1]
Ruta de Python:
['/usr/share/qgis/python', '/home/goyo/.qgis//python/plugins',
'/usr/share/qgis/python/plugins', '/usr/lib/python2.6',
'/usr/lib/python2.6/plat-linux2', '/usr/lib/python2.6/lib-tk',
'/usr/lib/python2.6/lib-old', '/usr/lib/python2.6/lib-dynload',
'/usr/lib/python2.6/dist-packages',
'/usr/lib/python2.6/dist-packages/PIL',
'/usr/lib/python2.6/dist-packages/gst-0.10',
'/usr/lib/pymodules/python2.6',
'/usr/lib/python2.6/dist-packages/gtk-2.0',
'/usr/lib/pymodules/python2.6/gtk-2.0',
'/usr/lib/python2.6/dist-packages/wx-2.8-gtk2-unicode',
'/usr/local/lib/python2.6/dist-packages']
i uninstalled all the packages, and added the repositories (ubuntu-gis /
qgis master / qgis-debian one a time) in the sources list and dont want to
install ¡¡¡¡¡¡¡¡¡¡¡¡, say
"you hold broken packages"
#The following packages have unmet dependencies:
Los siguientes paquetes tienen dependencias incumplidas:
qgis : Depende: libgdal1-1.7.0 pero no es instalable
Depende: libqgis1.9.0 pero no va a instalarse
Depende: qgis-providers (= 1.9.0+git20130527+6a352b7~precise1) pero
no va a instalarse
Recomienda: qgis-plugin-globe pero no va a instalarse
Recomienda: qgis-plugin-grass pero no va a instalarse
Recomienda: python-qgis pero no va a instalarse
E: No se pudieron corregir los problemas, usted ha retenido paquetes rotos.
#Failed to correct problems, you have held broken packages.
help¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¿
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130529/d1165c8b/attachment.html>
