[Qgis-user] Python Error
Goyo goyodiaz at gmail.com
Wed May 29 12:16:00 PDT 2013
2013/5/29 Luis M. Ruiz E. <geografoaplicado at gmail.com>:
> Hi Comunity¡¡¡¡¡¡¡¡¡¡
> i have a real big problem with python in ubuntu 13.04.
> i installed qgis since a 3 months, and no problems, but, when i want to use
> the open layers plugin, qgis crash, close unspectly. tired with the
> situation, i uninstall the program, but, when i try to re install, show me
> the following message:
> the python support is enabled:
> No se pudo cargar PyQGIS.
> El soporte para Python estará deshabilitado.
> Traceback (most recent call last):
>   File "", line 1, in
> RuntimeError: the sip module implements API v6.0 but the qgis.core
> module requires API v5.0
> Versión de Python:
> 2.6.4rc1 (r264rc1:75270, Oct 13 2009, 17:19:27)
> [GCC 4.4.1]
> Ruta de Python:
> ['/usr/share/qgis/python', '/home/goyo/.qgis//python/plugins',
> '/usr/share/qgis/python/plugins', '/usr/lib/python2.6',
> '/usr/lib/python2.6/plat-linux2', '/usr/lib/python2.6/lib-tk',
> '/usr/lib/python2.6/lib-old', '/usr/lib/python2.6/lib-dynload',
> '/usr/lib/python2.6/dist-packages',
> '/usr/lib/python2.6/dist-packages/PIL',
> '/usr/lib/python2.6/dist-packages/gst-0.10',
> '/usr/lib/pymodules/python2.6',
> '/usr/lib/python2.6/dist-packages/gtk-2.0',
> '/usr/lib/pymodules/python2.6/gtk-2.0',
> '/usr/lib/python2.6/dist-packages/wx-2.8-gtk2-unicode',
> '/usr/local/lib/python2.6/dist-packages']
> i uninstalled all the packages, and added the repositories (ubuntu-gis /
> qgis master / qgis-debian one a time) in the sources list and dont want to
> install ¡¡¡¡¡¡¡¡¡¡¡¡, say
> "you hold broken packages"
> #The following packages have unmet dependencies:
> Los siguientes paquetes tienen dependencias incumplidas:
>  qgis : Depende: libgdal1-1.7.0 pero no es instalable
>         Depende: libqgis1.9.0 pero no va a instalarse
>         Depende: qgis-providers (= 1.9.0+git20130527+6a352b7~precise1) pero
Looks like you are using the wrong repositories. Use only repositories
for raring, not precise.
Goyo
