[Qgis-user] Python Error
Luis M. Ruiz E. geografoaplicado at gmail.com
Wed May 29 12:33:19 PDT 2013
I MADE ALL THE POSIBILITIES , BUT NOTHING¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡
HELP ME PLEASE
2013/5/29 Goyo <goyodiaz at gmail.com>
> 2013/5/29 Luis M. Ruiz E. <geografoaplicado at gmail.com>:
> > Hi Comunity¡¡¡¡¡¡¡¡¡¡
> > i have a real big problem with python in ubuntu 13.04.
> > i installed qgis since a 3 months, and no problems, but, when i want to
> use
> > the open layers plugin, qgis crash, close unspectly. tired with the
> > situation, i uninstall the program, but, when i try to re install, show
> me
> > the following message:
> > the python support is enabled:
> > No se pudo cargar PyQGIS.
> > El soporte para Python estará deshabilitado.
> > Traceback (most recent call last):
> >   File "", line 1, in
> > RuntimeError: the sip module implements API v6.0 but the qgis.core
> > module requires API v5.0
> > Versión de Python:
> > 2.6.4rc1 (r264rc1:75270, Oct 13 2009, 17:19:27)
> > [GCC 4.4.1]
> > Ruta de Python:
> > ['/usr/share/qgis/python', '/home/goyo/.qgis//python/plugins',
> > '/usr/share/qgis/python/plugins', '/usr/lib/python2.6',
> > '/usr/lib/python2.6/plat-linux2', '/usr/lib/python2.6/lib-tk',
> > '/usr/lib/python2.6/lib-old', '/usr/lib/python2.6/lib-dynload',
> > '/usr/lib/python2.6/dist-packages',
> > '/usr/lib/python2.6/dist-packages/PIL',
> > '/usr/lib/python2.6/dist-packages/gst-0.10',
> > '/usr/lib/pymodules/python2.6',
> > '/usr/lib/python2.6/dist-packages/gtk-2.0',
> > '/usr/lib/pymodules/python2.6/gtk-2.0',
> > '/usr/lib/python2.6/dist-packages/wx-2.8-gtk2-unicode',
> > '/usr/local/lib/python2.6/dist-packages']
> > i uninstalled all the packages, and added the repositories (ubuntu-gis /
> > qgis master / qgis-debian one a time) in the sources list and dont want
> to
> > install ¡¡¡¡¡¡¡¡¡¡¡¡, say
> > "you hold broken packages"
> > #The following packages have unmet dependencies:
> > Los siguientes paquetes tienen dependencias incumplidas:
> >  qgis : Depende: libgdal1-1.7.0 pero no es instalable
> >         Depende: libqgis1.9.0 pero no va a instalarse
> >         Depende: qgis-providers (= 1.9.0+git20130527+6a352b7~precise1)
> pero
> Looks like you are using the wrong repositories. Use only repositories
> for raring, not precise.
> Goyo
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130529/ec4eefd6/attachment.html>
