[Qgis-user] Internal Server Error when PDF printing from QGIS Web Client
cdp cdaponte at synergyaspen.ca
Wed May 29 08:04:34 PDT 2013
Hi everyone,
When using the print option from the QGIS Web Client to print pdf, an
internal server error is returned.  The composer template used is a simple
view port with no other map items (eg. scales, legends, text boxes). we've
tried printing just a simple point with no background, a WMS aerial photo
with no additional layers, and several layers of varying style complexity
with no luck.
I've managed to change the default print format to png which works with no
issue in all cases, however PDF is really the preferred output.  Here is the
GetPrint link
http://gis.idn12.com/qgis/qgis_mapserv.fcgi?map=c:/projects/pt1.qgs&SERVICE=WMS&VERSION=1.3&REQUEST=GetPrint&FORMAT=png&EXCEPTIONS=application/vnd.ogc.se_inimage&TRANSPARENT=true&SRS=EPSG:3005&DPI=300&TEMPLATE=Composer%201&map0:extent=1239568.1,1322608.4,1401071.9,1452611.6&map0:rotation=0&map0:scale=500000&map0:grid_interval_x=2000&map0:grid_interval_y=2000&LAYERS=UWR
Anyone have any ideas of what the issue could be.
We are running QGIS Server with QGIS Web Client on a windows rackspace
server.
Thanks
C
View this message in context: http://osgeo-org.1560.x6.nabble.com/Internal-Server-Error-when-PDF-printing-from-QGIS-Web-Client-tp5056774.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
