[Qgis-user] Internal Server Error when PDF printing from QGIS Web Client
Andreas Neumann
a.neumann at carto.net
Wed May 29 08:12:29 PDT 2013
The parameters look correct to me.
On a Linux server you would need a running XServer and DISPLAY variable
defined to support PDF output - I don't know how this works on a Windows
server.
Any people out there with experience with QGIS Servers an Windows?
Andreas
On Wed, 29 May 2013 08:04:34 -0700 (PDT), cdp wrote:
> Hi everyone,
> When using the print option from the QGIS Web Client to print pdf, an
> internal server error is returned. The composer template used is a
> simple
> view port with no other map items (eg. scales, legends, text boxes).
> we've
> tried printing just a simple point with no background, a WMS aerial
> photo
> with no additional layers, and several layers of varying style
> complexity
> with no luck.
> I've managed to change the default print format to png which works
> with no
> issue in all cases, however PDF is really the preferred output. Here
> is the
> GetPrint link
> http://gis.idn12.com/qgis/qgis_mapserv.fcgi?map=c:/projects/pt1.qgs&SERVICE=WMS&VERSION=1.3&REQUEST=GetPrint&FORMAT=png&EXCEPTIONS=application/vnd.ogc.se_inimage&TRANSPARENT=true&SRS=EPSG:3005&DPI=300&TEMPLATE=Composer%201&map0:extent=1239568.1,1322608.4,1401071.9,1452611.6&map0:rotation=0&map0:scale=500000&map0:grid_interval_x=2000&map0:grid_interval_y=2000&LAYERS=UWR
> Anyone have any ideas of what the issue could be.
> We are running QGIS Server with QGIS Web Client on a windows
> rackspace
> server.
> Thanks
> C
> http://osgeo-org.1560.x6.nabble.com/Internal-Server-Error-when-PDF-printing-from-QGIS-Web-Client-tp5056774.html
> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
> Qgis-user mailing list
Andreas Neumann
Böschacherstrasse 10A
8624 Grüt (Gossau ZH)
Switzerland
