[Qgis-user] Processing plugin upgrade problem
Jesus Munoz Serrano
jesusmunozserrano at gmail.com
Thu Nov 7 03:33:02 PST 2013
It looks exactly the same:
/Applications/QGIS.app/Contents/MacOS/grass/bin:/Applications/QGIS.app/Contents/MacOS/grass/scripts:/Applications/QGIS.app/Contents/MacOS/../Resources/grass/scripts/:/usr/bin:/bin:/usr/sbin:/sbin
On Nov 7, 2013, at 12:27 PM, Julian Bogdani <jbogdani at gmail.com> wrote:
> Hello,
> Could you please copy&paste the value of the PATH variable in Settings > Options > System > Current environment variables
> I do not have the /Applications/QGIS.app/Contents/MacOS/bin in this list and I’m not able to add it manually (this is a read only list)
> Actually this is the value of my PATH variable: /Applications/QGIS.app/Contents/MacOS/grass/bin:/Applications/QGIS.app/Contents/MacOS/grass/scripts:/Applications/QGIS.app/Contents/MacOS/../Resources/grass/scripts/:/usr/bin:/bin:/usr/sbin:/sbin
> Julian Bogdani
> http://bradypus.net
> On 7 Nov 2013, at 12:10 , Jesus Munoz Serrano <jesusmunozserrano at gmail.com> wrote:
>> Hi Julian,
>> I had the same warning when I upgraded the processing plugin (I am using mac OS X 10.8 and QGIS 2.0.1). I exit QGIS and open it again and the processing plugin was there. Then I used kernel density estimation algorithm inside the SAGA group and it worked fine. What algorithm have you try? Can I check anything in my computer to help you?
>> On Nov 7, 2013, at 11:54 AM, Victor Olaya <volayaf at gmail.com> wrote:
>>> No, that should be enough, but unfortunately my knowledge of Mac OSX
>>> is zero, so i am afraid I cannot help you. Let's see if other mac
>>> users can help you... :-(
>>> Cheers
>>> 2013/11/7 Julian Bogdani <jbogdani at gmail.com>:
>>>> Hi Victor,
>>>> SAGA should be installed with QGIS, isn’t it? I can see the saga_cmd in
>>>> /Applications/QGIS.app/Contents/MacOS/bin and I added this path to my
>>>> .bash_profile file
>>>> Running saga_cmd -v on my terminal I have: SAGA Version: 2.1.0
>>>> Closing QGIS and restarting, I found no changes, still the same error when I
>>>> try to run any SAGA algorithm: Missing dependency
>>>> Should I install Saga separately?
>>>> On 7 Nov 2013, at 11:37 , Victor Olaya <volayaf at gmail.com> wrote:
>>>> Is SAGA installed and in PATH? can you open a console and run
>>>> saga_cmd? what do you get?
>>>> Notice that SAGA 2.1.0 is needed in mac, but the default Processing
>>>> configuration is to have 2.0.8 compatibility enabled...
>>>> Trying to run any SAGA algorithm I get this message now:
>>>> Missing dependency.This algorithm cannot be run :-(
>>>> This algorithm requires SAGA to be run.Unfortunately, it seems that SAGA is
>>>> not installed in your system, or it is not correctly configured to be used
>>>> from QGIS
>>>> Click here to know more about how to install and configure SAGA to be used
>>>> with QGIS
>>>> I just reinstalled GDAL and QGIS, upgraded Processing, and checked that SAGA
>>>> was activated (Processing > Options and Configurations > Providers > SAGA)
>>>> Julian Bogdani
>>>> http://bradypus.net
>>>> On 7 Nov 2013, at 11:23 , G. Allegri <giohappy at gmail.com> wrote:
>>>> I've noticed that it happens with Windows standalone installer too but not
>>>> with OSGeo4W.
>>>> giovanni
>>>> 2013/11/7 Werner Macho <werner.macho at gmail.com>
>>>> Hi!
>>>> I had the same error .. It is nothing serious .. it tells you more or
>>>> less that the upgrade was successful .. (because it does not find old
>>>> files)
>>>> just close and reopen QGIS and everything will be fine ..
>>>> regards
>>>> Werner
>>>> On Thu, Nov 7, 2013 at 12:16 PM, Julian Bogdani <jbogdani at gmail.com>
>>>> wrote:
>>>> Hello all,
>>>> I’m running latest QGIS (2.0.1-3) installed from Kyngchaos repo, on
>>>> MacOS X
>>>> 10.9 (Mavericks)
>>>> trying to upgrade Processing plugin, to get advantage of this fix: Bug
>>>> #8877: Kriging from SAGA (Processing) fails to run I get the following
>>>> error.
>>>> Any hint? Thank you
>>>> Couldn't load plugin 'processing' from
>>>> ['/Applications/QGIS.app/Contents/MacOS/../Resources/python/plugins/processing',
>>>> '/Applications/QGIS.app/Contents/MacOS/../Resources/python',
>>>> '/Users/jbogdani/.qgis2/python',
>>>> '/Users/jbogdani/.qgis2/python/plugins',
>>>> '/Applications/QGIS.app/Contents/MacOS/../Resources/python/plugins',
>>>> '/Library/Frameworks/SQLite3.framework/Versions/B/Python/2.7',
>>>> '/Library/Frameworks/GEOS.framework/Versions/3/Python/2.7',
>>>> '/Library/Python/2.7/site-packages/numpy-override',
>>>> '/Library/Frameworks/GDAL.framework/Versions/1.10/Python/2.7/site-packages',
>>>> '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python27.zip',
>>>> '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7',
>>>> '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/plat-darwin',
>>>> '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/plat-mac',
>>>> '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/plat-mac/lib-scriptpackages',
>>>> '/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python',
>>>> '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-tk',
>>>> '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-old',
>>>> '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-dynload',
>>>> '/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python/PyObjC',
>>>> '/Library/Python/2.7/site-packages',
>>>> '/Applications/QGIS.app/Contents/Resources/python/plugins/fTools/tools']
>>>> Traceback (most recent call last):
>>>> File
>>>> "/Applications/QGIS.app/Contents/MacOS/../Resources/python/qgis/utils.py",
>>>> line 182, in loadPlugin
>>>> __import__(packageName)
>>>> File
>>>> line 453, in _import
>>>> mod = _builtin_import(name, globals, locals, fromlist, level)
>>>> File "/Users/jbogdani/.qgis2/python/plugins/processing/__init__.py",
>>>> line
>>>> 29, in
>>>> from processing.tools.general import *
>>>> File
>>>> File
>>>> "/Users/jbogdani/.qgis2/python/plugins/processing/tools/general.py",
>>>> line 29, in
>>>> from processing.core.Processing import Processing
>>>> File
>>>> File
>>>> "/Applications/QGIS.app/Contents/MacOS/../Resources/python/plugins/processing/core/Processing.py",
>>>> line 35, in
>>>> from processing.gui.AlgorithmExecutor import AlgorithmExecutor
>>>> File
>>>> ImportError: No module named AlgorithmExecutor
>>>> Python version:
>>>> 2.7.5 (default, Aug 25 2013, 00:04:04)
>>>> [GCC 4.2.1 Compatible Apple LLVM 5.0 (clang-500.0.68)]
>>>> QGIS version:
>>>> 2.0.1-Dufour Dufour, f738351
>>>> Python path:
>>>> Julian Bogdani
>>>> http://bradypus.net
>>>> _______________________________________________
>>>> Qgis-user mailing list
>>>> Qgis-user at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
>>>> Giovanni Allegri
>>>> http://about.me/giovanniallegri
>>>> blog: http://blog.spaziogis.it
>>>> GEO+ geomatica in Italia http://bit.ly/GEOplus
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20131107/d29d1d3f/attachment.html>
