[Qgis-user] Processing plugin upgrade problem
Jesus Munoz Serrano jesusmunozserrano at gmail.com
Thu Nov 7 03:48:27 PST 2013
Hi again Julian,
I just tried running the raster calculator algorithm within the SAGA module and I got an error. First it said that the algorithm couldn't be run for some error (sorry but I don't remember the exact words). Then I tried a second time and it said:
			Oooops! The following output layers could not be open
Result: /var/folders/k8/1gjgs_cn6rv4blrm7s5pjyr80000gn/T/processing/4fe7b400fbd04eefb764e2b7a8ff1e5d/RESULT.tif
			The above files could not be opened, which probably indicates that they were not correctly produced by the 				executed algorithm
			Checking the log information might help you see why those layers were not created as expected
			This algorithm requires SAGA to be run. A test to check if SAGA is correctly installed and configured in your system 			has 	been performed, with the following result:
			SAGA seems to be correctly installed and configured
Don't know if this is somehow related to your issue
On Nov 7, 2013, at 12:33 PM, Jesus Munoz Serrano <jesusmunozserrano at gmail.com> wrote:
> It looks exactly the same:
> /Applications/QGIS.app/Contents/MacOS/grass/bin:/Applications/QGIS.app/Contents/MacOS/grass/scripts:/Applications/QGIS.app/Contents/MacOS/../Resources/grass/scripts/:/usr/bin:/bin:/usr/sbin:/sbin
> On Nov 7, 2013, at 12:27 PM, Julian Bogdani <jbogdani at gmail.com> wrote:
>> Hello,
>> Could you please copy&paste the value of the PATH variable in Settings > Options > System > Current environment variables
>> I do not have the /Applications/QGIS.app/Contents/MacOS/bin in this list and I’m not able to add it manually (this is a read only list)
>> Actually this is the value of my PATH variable: /Applications/QGIS.app/Contents/MacOS/grass/bin:/Applications/QGIS.app/Contents/MacOS/grass/scripts:/Applications/QGIS.app/Contents/MacOS/../Resources/grass/scripts/:/usr/bin:/bin:/usr/sbin:/sbin
>> Julian Bogdani
>> http://bradypus.net
>> On 7 Nov 2013, at 12:10 , Jesus Munoz Serrano <jesusmunozserrano at gmail.com> wrote:
>>> Hi Julian,
>>> I had the same warning when I upgraded the processing plugin (I am using mac OS X 10.8 and QGIS 2.0.1). I exit QGIS and open it again and the processing plugin was there. Then I used kernel density estimation algorithm inside the SAGA group and it worked fine. What algorithm have you try? Can I check anything in my computer to help you?
>>> On Nov 7, 2013, at 11:54 AM, Victor Olaya <volayaf at gmail.com> wrote:
>>>> No, that should be enough, but unfortunately my knowledge of Mac OSX
>>>> is zero, so i am afraid I cannot help you. Let's see if other mac
>>>> users can help you... :-(
>>>> Cheers
>>>> 2013/11/7 Julian Bogdani <jbogdani at gmail.com>:
>>>>> Hi Victor,
>>>>> SAGA should be installed with QGIS, isn’t it? I can see the saga_cmd in
>>>>> /Applications/QGIS.app/Contents/MacOS/bin and I added this path to my
>>>>> .bash_profile file
>>>>> Running saga_cmd -v on my terminal I have: SAGA Version: 2.1.0
>>>>> Closing QGIS and restarting, I found no changes, still the same error when I
>>>>> try to run any SAGA algorithm: Missing dependency
>>>>> Should I install Saga separately?
>>>>> On 7 Nov 2013, at 11:37 , Victor Olaya <volayaf at gmail.com> wrote:
>>>>> Is SAGA installed and in PATH? can you open a console and run
>>>>> saga_cmd? what do you get?
>>>>> Notice that SAGA 2.1.0 is needed in mac, but the default Processing
>>>>> configuration is to have 2.0.8 compatibility enabled...
>>>>> Trying to run any SAGA algorithm I get this message now:
>>>>> Missing dependency.This algorithm cannot be run :-(
>>>>> This algorithm requires SAGA to be run.Unfortunately, it seems that SAGA is
>>>>> not installed in your system, or it is not correctly configured to be used
>>>>> from QGIS
>>>>> Click here to know more about how to install and configure SAGA to be used
>>>>> with QGIS
>>>>> I just reinstalled GDAL and QGIS, upgraded Processing, and checked that SAGA
>>>>> was activated (Processing > Options and Configurations > Providers > SAGA)
>>>>> Julian Bogdani
>>>>> http://bradypus.net
>>>>> On 7 Nov 2013, at 11:23 , G. Allegri <giohappy at gmail.com> wrote:
>>>>> I've noticed that it happens with Windows standalone installer too but not
>>>>> with OSGeo4W.
>>>>> giovanni
>>>>> 2013/11/7 Werner Macho <werner.macho at gmail.com>
>>>>> Hi!
>>>>> I had the same error .. It is nothing serious .. it tells you more or
>>>>> less that the upgrade was successful .. (because it does not find old
>>>>> files)
>>>>> just close and reopen QGIS and everything will be fine ..
>>>>> regards
>>>>> Werner
>>>>> On Thu, Nov 7, 2013 at 12:16 PM, Julian Bogdani <jbogdani at gmail.com>
>>>>> wrote:
>>>>> Hello all,
>>>>> I’m running latest QGIS (2.0.1-3) installed from Kyngchaos repo, on
>>>>> MacOS X
>>>>> 10.9 (Mavericks)
>>>>> trying to upgrade Processing plugin, to get advantage of this fix: Bug
>>>>> #8877: Kriging from SAGA (Processing) fails to run I get the following
>>>>> error.
>>>>> Any hint? Thank you
>>>>> Couldn't load plugin 'processing' from
>>>>> ['/Applications/QGIS.app/Contents/MacOS/../Resources/python/plugins/processing',
>>>>> '/Applications/QGIS.app/Contents/MacOS/../Resources/python',
>>>>> '/Users/jbogdani/.qgis2/python',
>>>>> '/Users/jbogdani/.qgis2/python/plugins',
>>>>> '/Applications/QGIS.app/Contents/MacOS/../Resources/python/plugins',
>>>>> '/Library/Frameworks/SQLite3.framework/Versions/B/Python/2.7',
>>>>> '/Library/Frameworks/GEOS.framework/Versions/3/Python/2.7',
>>>>> '/Library/Python/2.7/site-packages/numpy-override',
>>>>> '/Library/Frameworks/GDAL.framework/Versions/1.10/Python/2.7/site-packages',
>>>>> '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python27.zip',
>>>>> '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7',
>>>>> '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/plat-darwin',
>>>>> '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/plat-mac',
>>>>> '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/plat-mac/lib-scriptpackages',
>>>>> '/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python',
>>>>> '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-tk',
>>>>> '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-old',
>>>>> '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-dynload',
>>>>> '/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python/PyObjC',
>>>>> '/Library/Python/2.7/site-packages',
>>>>> '/Applications/QGIS.app/Contents/Resources/python/plugins/fTools/tools']
>>>>> Traceback (most recent call last):
>>>>> File
>>>>> "/Applications/QGIS.app/Contents/MacOS/../Resources/python/qgis/utils.py",
>>>>> line 182, in loadPlugin
>>>>>  __import__(packageName)
>>>>> File
>>>>> line 453, in _import
>>>>>  mod = _builtin_import(name, globals, locals, fromlist, level)
>>>>> File "/Users/jbogdani/.qgis2/python/plugins/processing/__init__.py",
>>>>> line
>>>>> 29, in
>>>>>  from processing.tools.general import *
>>>>> File
>>>>> File
>>>>> "/Users/jbogdani/.qgis2/python/plugins/processing/tools/general.py",
>>>>> line 29, in
>>>>>  from processing.core.Processing import Processing
>>>>> File
>>>>> File
>>>>> "/Applications/QGIS.app/Contents/MacOS/../Resources/python/plugins/processing/core/Processing.py",
>>>>> line 35, in
>>>>>  from processing.gui.AlgorithmExecutor import AlgorithmExecutor
>>>>> File
>>>>> ImportError: No module named AlgorithmExecutor
>>>>> Python version:
>>>>> 2.7.5 (default, Aug 25 2013, 00:04:04)
>>>>> [GCC 4.2.1 Compatible Apple LLVM 5.0 (clang-500.0.68)]
>>>>> QGIS version:
>>>>> 2.0.1-Dufour Dufour, f738351
>>>>> Python path:
>>>>> Julian Bogdani
>>>>> http://bradypus.net
>>>>> _______________________________________________
>>>>> Qgis-user mailing list
>>>>> Qgis-user at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
>>>>> Giovanni Allegri
>>>>> http://about.me/giovanniallegri
>>>>> blog: http://blog.spaziogis.it
>>>>> GEO+ geomatica in Italia http://bit.ly/GEOplus
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20131107/5b3c42fd/attachment.html>
