[Qgis-user] Spurious Cryllic Script
JOHN WEBBER john.m.webber at btinternet.com
Fri Oct 4 06:12:15 PDT 2013
Many thanks Goyo, you have saved me from tearing out what remains of my hair.  I found the function where you described and found it to be set to "UK".  To effect some kind of change I selected "English US"  and restarted Qgis and now I have everything displaying in English but the US version in both 1.8 and 2.0.
As a further experiment I then changed the locale in 1.8 back to UK and restarted the program again.  It opened displaying the cryllic/English once again.  It appears that there is a problem somewhere within the "UK" Locale setting.  So I have reset it to US English once again.
Thanks for your help.
John Webber
To: JOHN WEBBER <john.m.webber at btinternet.com>
Cc: "qgis-user at lists.osgeo.org" <qgis-user at lists.osgeo.org>
Sent: Thursday, 3 October 2013, 20:38
Subject: Re: [Qgis-user] Spurious Cryllic Script
2013/10/3 JOHN WEBBER <john.m.webber at btinternet.com>:
> Opening Qgis 1.8 a few days ago I was presented with menus where some were
> in English and others in a Cryllic script.  I have checked as many language
> settings as I can find on the operating system and they still show English
> as the language and UK as the location.  I cannot see if there is a language
> option in Qgis as one does not show in the few entries on the drop downs
> that are in English.  Also I have run a full security scan and that did not
> pull up any interference.
> My next move was to download Qgis 2.0.1.  This initially opened showing all
> English but when I opened it again the next day that also displayed Cryllic
> and English.  At this point I uninstalled both versions then downloaded
> 2.0.1 again and it opened showing both scripts.  Downloading 1.8 also
> produced both scripts on opening.
> I was able to work reasonably well with 1.8 as I am familiar with the menus
> and could find items I needed.  All well and good until it came to labelling
> points on a shapefile layer.  Although they were entered in English they
> displayed in Cryllic.
> Can anyone help resolve this situation please?  Maybe all I need is the
> location of a language selector in the menu system but I would need it in
> the form of 3rd menu list 5th item as it is obviously one of the Cryllic
> entries assuming there is one.
You almost hit the spot!
Settings > Options > Locale
3rd item in the menu bar
5th item in the drop down menu
10th item in the list on the left
Mark the checkbox (it says "Override system locale")
Select a language in the dropdown list (look for a known flag if you
can' read the names).
I hope you can find the OK button. Then restart QGIS.
Goyo
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20131004/86921107/attachment.html>
