[Qgis-user] Saving layers
Jonathan Moules
jonathanmoules at warwickshire.gov.uk
Thu Oct 17 09:55:49 PDT 2013
Hi Richard,
That's useful to know, however I was planning on using it with Oracle
layers so it wouldn't work for me. Basically what we do with ArcMap (.lyr)
and MapInfo (.tab) is create links to data which we share on a network
drive so that our users can easily access our data pre-styled. It works
quite well so if we go toward QGIS we'd want to use it there too.
Cheers,
Jonathan
On 17 October 2013 17:47, Richard Duivenvoorde <rdmailings at duif.net> wrote:
> On 17-10-13 15:36, Jonathan Moules wrote:
> > Hi List,
> > I'm wondering if QGIS can save links to layers as stand alone files,
> > similar to how ArcMap does it.
> > I know I can save the style, but I want to save everything about the
> > layer including data location etc in a file which I can then share with
> > others. The style only saves the style.
> > I can't seem to find such a function - is there one?
> Hi Jonathan,
> one 'hidden' feature is that if you save a style as a qml file next to
> your data (shape file), and name it exactly the same as your shape,
> loading the shp in qgis will load the style with it.
> BUT: only working with filebased data, and NOT saving your extent I think.
> You can save a project, and use it as a template. And if I recall
> correct there was some way to use one project as a subprobject for
> another one, but I cannot find it anymore...
> Regards,
> Richard
This transmission is intended for the named addressee(s) only and may
contain sensitive or protectively marked material up to RESTRICTED and
should be handled accordingly. Unless you are the named addressee (or
authorised to receive it for the addressee) you may not copy or use it, or
disclose it to anyone else. If you have received this transmission in error
please notify the sender immediately. All email traffic sent to or from us,
including without limitation all GCSX traffic, may be subject to recording
and/or monitoring in accordance with relevant legislation.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20131017/f00bd80e/attachment.html>
