[Qgis-user] Saving layers
Lene Fischer lfi at life.ku.dk
Thu Oct 17 10:34:56 PDT 2013
Hi Jonathan
If you have a standard style - you can in Styles make a 'Save as default'. When you open a similar layer it will have the same style.
Regards
Lene Fischer
Fra: qgis-user-bounces at lists.osgeo.org [qgis-user-bounces at lists.osgeo.org] på vegne af Jonathan Moules [jonathanmoules at warwickshire.gov.uk]
Sendt: 17. oktober 2013 18:55
Til: richard at duif.net; qgis-user at lists.osgeo.org
Emne: Re: [Qgis-user] Saving layers
Hi Richard,
That's useful to know, however I was planning on using it with Oracle layers so it wouldn't work for me. Basically what we do with ArcMap (.lyr) and MapInfo (.tab) is create links to data which we share on a network drive so that our users can easily access our data pre-styled. It works quite well so if we go toward QGIS we'd want to use it there too.
Cheers,
Jonathan
On 17 October 2013 17:47, Richard Duivenvoorde <rdmailings at duif.net<mailto:rdmailings at duif.net>> wrote:
On 17-10-13 15:36, Jonathan Moules wrote:
> Hi List,
>   I'm wondering if QGIS can save links to layers as stand alone files,
> similar to how ArcMap does it.
> I know I can save the style, but I want to save everything about the
> layer including data location etc in a file which I can then share with
> others. The style only saves the style.
> I can't seem to find such a function - is there one?
Hi Jonathan,
one 'hidden' feature is that if you save a style as a qml file next to
your data (shape file), and name it exactly the same as your shape,
loading the shp in qgis will load the style with it.
BUT: only working with filebased data, and NOT saving your extent I think.
You can save a project, and use it as a template. And if I recall
correct there was some way to use one project as a subprobject for
another one, but I cannot find it anymore...
Regards,
Richard
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20131017/ef67aa96/attachment.html>
