[Qgis-user] Question for QGIS user list
Alexandre Neto senhor.neto at gmail.com
Thu Sep 5 08:43:54 PDT 2013
Hello Sundas,
All you need to to, is determine the number of classes you want (8?),
choose any of the methods you stated and press classify.
After that, you can double-click the value field from each interval, and
set your desired values. You should also change the label, and in there you
can use the number of decimal you wish to show.
Hope it helped.
Alexandre Neto
On Thu, Sep 5, 2013 at 3:23 PM, Sundas Ali <s.ali at mcb.org.uk> wrote:
>  Dear QGIS user list,****
> I want to post this question on the QGIS user list, please post this:****
> My question is relating to the series on the side of a map that we create
> on QGIS (which gives intervals/ranges by quantile level). I wanted to know
> how I can adjust these ranges? ****
> For example, at the moment, the ranges in my map are:****
> 0.00-9.48****
> 9.48-18.97****
> 18.10-28.5****
> 85.35-94.83****
> etc****
> (these are % of Muslims)****
> I want to change these ranges to:****
> <5%, ****
> >5% & <10%****
> >10% & <15%****
> >15% & <20%****
> >20% & <25%****
> >25% & <30%****
> >30% & <35%****
> >35%****
> How can I do this? I try and do this by right-clicking on the
> 'LSOA_Religion' layer and going to 'Properties', and then I have the option
> of changing the ranges by 'Equal Interval', 'Quantile', 'Natural Breaks
> (Jenks)', 'Standard Deviation', and 'Pretty Breaks'. But there is no option
> to alter these ranges manually. How can I do this? ****
> Also, how can I keep the number of the range to 2 decimal places?****
> I look forward to hearing from you all.****
> All best,****
> Sundas****
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130905/25f6906d/attachment.html>
