[Qgis-user] Saga not working with "In processing" aka sextante
matteo matteo.ghetta at gmail.com
Mon Sep 9 02:10:52 PDT 2013
Il 09/09/2013 10:49, Victor Olaya ha scritto:
> hmmmm, let' see
> can you tell me if there is any output in the log?. There should be a
> test run by the saga algorithm before opening the dialog, which tries
> to run the centroids algorithm on a test layer. Can you send me the
> result of that test, which should be in the log (remember to enable
> saga logging if it is not already enabled)
Here it is:
SAGA execution console output
error: executing module [Polygon Centroids]
_____________________________________________
library path: /usr/lib/saga
library name: libshapes_polygons
module name : Polygon Centroids
author : (c) 2003 by O.Conrad
go...
Load shapes:
/usr/share/qgis/python/plugins/processing/tests/data/points.shp...
ready
okay
Polygon Centroids: Invalid parameters!
Shapes: Polygons
BTW: no matter which algorithms I choose, the message always refers to
the polygon centroids. Is that normal?
Is it possible that the changes you made on Friday have not been merged
in the repo?
Thanks
Matteo
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130909/32910c26/attachment.html>
