[Qgis-user] Saga not working with "In processing" aka sextante
Victor Olaya volayaf at gmail.com
Mon Sep 9 02:54:14 PDT 2013
yes, that doesn't include the change
You can see that it is trying to call centroids to perform the
test...but it passes a points layer. It should pass a polygon one.
That was the change i introduced
When master gets updated, you should get the new code, which should
perform the test correctly
Cheers, and thanks again!
2013/9/9 matteo <matteo.ghetta at gmail.com>:
> Il 09/09/2013 10:49, Victor Olaya ha scritto:
> hmmmm, let' see
> can you tell me if there is any output in the log?. There should be a
> test run by the saga algorithm before opening the dialog, which tries
> to run the centroids algorithm on a test layer. Can you send me the
> result of that test, which should be in the log (remember to enable
> saga logging if it is not already enabled)
> Here it is:
> SAGA execution console output
> error: executing module [Polygon Centroids]
> _____________________________________________
> library path: /usr/lib/saga
> library name: libshapes_polygons
> module name : Polygon Centroids
> author : (c) 2003 by O.Conrad
> go...
> Load shapes:
> /usr/share/qgis/python/plugins/processing/tests/data/points.shp...
> ready
> okay
> Polygon Centroids: Invalid parameters!
> Shapes: Polygons
> BTW: no matter which algorithms I choose, the message always refers to the
> polygon centroids. Is that normal?
> Is it possible that the changes you made on Friday have not been merged in
> the repo?
> Thanks
> Matteo
