[Qgis-user] Saga and sextante
Goyo goyodiaz at gmail.com
Tue Sep 10 09:26:33 PDT 2013
Not a big deal, I just thought it might be a packaging issue or something.
2013/9/10 Victor Olaya <volayaf at gmail.com>:
> Goyo
> SEXTANTE has been renamed to Processing. That SEXTANTE plugin you have
> is an older one that you should remove. SEXTANTE does not exist
> anymore in QGIS, but the plugin system doesn't know that Processing is
> actually SEXTANTE, so it does not remove one when adding the other
> plugin. You have to do it manually
> Hope this helps
> Cheers
> 2013/9/10 Goyo <goyodiaz at gmail.com>:
>> It seems to be working now, at least I get a gui. But I noticed there
>> is a Processing plugin (which works) and a SEXTANTE plugin (which does
>> not work).
