[Qgis-user] Saga and sextante
Victor Olaya
volayaf at gmail.com
Tue Sep 10 00:27:34 PDT 2013
Goyo
SEXTANTE has been renamed to Processing. That SEXTANTE plugin you have
is an older one that you should remove. SEXTANTE does not exist
anymore in QGIS, but the plugin system doesn't know that Processing is
actually SEXTANTE, so it does not remove one when adding the other
plugin. You have to do it manually
Hope this helps
Cheers
2013/9/10 Goyo <goyodiaz at gmail.com>:
> It seems to be working now, at least I get a gui. But I noticed there
> is a Processing plugin (which works) and a SEXTANTE plugin (which does
> not work).
> Goyo
> 2013/9/6 Goyo <goyodiaz at gmail.com>:
>> 2013/9/6 Victor Olaya <volayaf at gmail.com>:
>>> Telmo
>>> Can you confirm that you are using the version provided with osgeo4w
>>> (which is still 2.0.8) and you have enabled 2.0.8 compatibility (which
>>> is not enabled by default)?
>> I can confirm this. SAGA 2.0.8 is installed from OSGeo4W, SAGA
>> provider activated, SAGA 2.0.8 comptibility enabled, SAGA folder
>> D:/OSGeo4w/apps\saga (which I changed to D:\OSGeo4w\apps\saga without
>> any effect).
>> Clicking on execute any SAGA algorhithm this message appears:
>> Missing dependency.This algorithm cannot be run :-(
>> This algorithm requires SAGA to be run.Unfortunately, it seems that
>> SAGA is not installed in your system, or it is not correctly
>> configured to be used from QGIS
>> Click here to know more about how to install and configure SAGA to be
>> used with QGIS
>> Goyo
