[Qgis-user] Saga and sextante
Goyo
goyodiaz at gmail.com
Tue Sep 10 00:19:45 PDT 2013
It seems to be working now, at least I get a gui. But I noticed there
is a Processing plugin (which works) and a SEXTANTE plugin (which does
not work).
Goyo
2013/9/6 Goyo <goyodiaz at gmail.com>:
> 2013/9/6 Victor Olaya <volayaf at gmail.com>:
>> Telmo
>> Can you confirm that you are using the version provided with osgeo4w
>> (which is still 2.0.8) and you have enabled 2.0.8 compatibility (which
>> is not enabled by default)?
> I can confirm this. SAGA 2.0.8 is installed from OSGeo4W, SAGA
> provider activated, SAGA 2.0.8 comptibility enabled, SAGA folder
> D:/OSGeo4w/apps\saga (which I changed to D:\OSGeo4w\apps\saga without
> any effect).
> Clicking on execute any SAGA algorhithm this message appears:
> Missing dependency.This algorithm cannot be run :-(
> This algorithm requires SAGA to be run.Unfortunately, it seems that
> SAGA is not installed in your system, or it is not correctly
> configured to be used from QGIS
> Click here to know more about how to install and configure SAGA to be
> used with QGIS
> Goyo
