[Qgis-user] new user
Albin Blaschka albin.blaschka at standortsanalyse.net
Thu Sep 12 06:52:57 PDT 2013
Hello!
Ah, ok, yes.
I, myself use Inkscape for that purpose...
For that I change between PDF and SVG export, as specially in the older
versions of QGIS the SVG-export was not the best and depending on the OS
I am on...
(/me working with different GIS - software since 1997 or something...)
Depends what the map is used for...
Albin
Am 12.09.2013 15:47, schrieb Mike Shand:
> Albin,
> You are correct that SVG does cause some problems and often generates an
> error message which I usually ignore when exporting a file.
> A Pdf does work in Illustrator but I have had better success with SVG,
> especially if you wish to edit any map features or separate them into
> layers.
> Of course QGIS purists would say why not do everything in QGIS, the
> reality is that many cartographers (for the moment) prefer to finalise
> their maps in a graphics package such as Adobe Illustrator.  Exporting
> from ArcGIS to Adobe Illustrator (and retaining layers) is also a common
> route used by cartographers.
> Mike
> Qgis-user mailing list
| Albin Blaschka, Mag.rer.nat.
| Etrichstrasse 26, A-5020 Salzburg
| * www.albinblaschka.info *
| * www.researchgate.net/profile/Albin_Blaschka *
| - It's hard to live in the mountains, hard but not hopeless!
