[Qgis-user] new user
Nick Hopton
nhopton at gmail.com
Fri Sep 13 02:31:49 PDT 2013
Hi Gill,
I might not understand your problem fully, but I think that as a newcomer to
QGIS a reasonable approach would be to load your OS OpenData map images
first and then load the contours. (I'd keep clear of the OpenData contour
DXFs if I were you and go for the new contour data in shapefile format.)
Once you have something that looks reasonable on the screen you could then
export a high-res image from the Print Composer that could be loaded into
Photoshop.
>From what you have written I think your base mapping must be OS VectorMap
District rasters. If I remember rightly these have a resolution of around
250 dpi so it probably wouldn't make much sense to export an image from the
Print Composer at much greater than this.
Cheers,
Nick.
View this message in context: http://osgeo-org.1560.x6.nabble.com/new-user-tp5077199p5077664.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
