[Qgis-user] Error while loading c run time libraries
Alex Mandel tech_dev at wildintellect.com
Fri Sep 13 11:32:35 PDT 2013
On 09/13/2013 11:15 AM, Gerardo Jimenez wrote:
> I installed  the OSGeoW qgis-dev and when I try to execute the program I have this messhe box
> Run time errorProgram c:\osgeowW64\bin\qgis-dev-bin.exeR6034An application has made an attempt to load the c runtime library incorrectly. Please contact the application´s support team for more information
> After clicling ok on the dialog box the program starts, neverthe less I tried to use the georefercer and the raster image that I loaded shows a gray square with jagged colors on top.
> I tried to reinstall the program and also run it as an administrator and no luck at all
> Gerardo Jiménez Delgado
> Instituto de Investigaciones Antropológicas
> Universidad Nacional Autónoma de México
> Ciudad Universitaria s/n
> Coyoacan 04510
> Mexico City
> Mexico
> 56 22 95 16
Gerardo, please report this on the osgeo4w mailing list as that is an
experimental 64bit build of osgeo4w.
http://lists.osgeo.org/mailman/listinfo/osgeo4w-dev
If you want to make sure you have a working version please use the
regular osgeo4w installer not the 64bit.
Thanks,
Alex
