[Qgis-user] Downloading GPS data from Garmin etrex vista hcx
Santiago Moreno
santiago.moreno at upm.es
Sat Sep 21 15:40:51 PDT 2013
Thank you Andre!
Your suggestion was helpful. Using the default command lines (garmin
serial) and Port: usb: , I was able to communicate my Garmin GPS with Q-GIS.
Regards,
Santiago
Message: 7
Date: Fri, 20 Sep 2013 18:25:49 +0200
To: qgis-user at lists.osgeo.org
Subject: Re: [Qgis-user] Downloading GPS data from Garmin etrex vista
hcx
Message-ID: <l1hsvs$cea$1 at ger.gmane.org>
Content-Type: text/plain; charset=ISO-8859-1; format=flowed
Am 20.09.2013 11:17, schrieb Santiago Moreno:
> Hello,
> My Garmin etrex vista hcx has no problems transfering waypoints to
> mapsource. However I can?t directly transfer waypoinst to Quantum GIS.
> The Quantum GIS GPS tool is configured as indicated below. I always get
> the message: "The layer . . . is not a valid layer and can not be added
> to the map". I will apreciate any suggestion to solve this problem.
> Santiago
> GPS device: Garmin USB
> Port: usb:
> Feature type: waypoints
> Comand lines:
> %babel -w -i garmin -f usb: -o gpx -F %out
It works for me with my Garmin etrex Legend Hcx under Windows 7 with:
Port: usb:
and under Settings with the default:
%babel -w -i garmin -o gpx "%in" "%out"
If it does not work, open a command window in your Lisboa installation
path, enter qgis.bat, and then gpsbabel to see if qgis can find gpsbabel.
HTH,
Andr? Joost
