[Qgis-user] QGIS 2.0 - OSX - georeferencing plugin missing ?
Teodoro Laino teodoro.laino at gmail.com
Mon Sep 23 13:18:52 PDT 2013
On Sep 23, 2013, at 10:10 PM, Larry Shaffer <larrys at dakotacarto.com> wrote:
> Thanks for your continued work on this. I'm beginning to think it may be a difference between the kyngchaos.com GDAL_Complete release on 9-2 and the one I am using for nightly builds, 8-19. Unfortunately, there is no direct link to the previous version available (though I have both locally). I ran both packge installers through Pacifist, and it looks like nothing is missing in the latest, so…
Thanks to you Larry - I understand that it is one of those silly issues to solve.. but.. you had a very good idea (see below)
> I will see about testing some clean installs on a separate Mac here, today.
> In the meantime, do you get any dylib error messages under the Plugins tab in the View-->Panels-->Log Messages panel? This is where you may see errors about loading C++ or Python plugins. Also, you can directly launch the QGIS binary, embedded in the app bundle (<app>/Contents/MacOS/QGIS), in Terminal and see if any errors show up in Terminal output.
Ok.. You found it! In the Log Messages Panel (Plugin) I get this one:
Failed to load /Applications/QGIS.app/Contents/MacOS/../PlugIns/qgis/libgeorefplugin.so (Reason: Cannot load library /Applications/QGIS.app/Contents/MacOS/../PlugIns/qgis/libgeorefplugin.so: (dlopen(/Applications/QGIS.app/Contents/MacOS/../PlugIns/qgis/libgeorefplugin.so, 5): Library not loaded: /Library/Frameworks/GSL.framework/Versions/1/GSL
  Referenced from: /Applications/QGIS.app/Contents/PlugIns/qgis/libgeorefplugin.so
  Reason: image not found))
Apparently I'm missing the GSL framework… Did I miss to install it? Where can I find that?
> Btw, you might consider uploading your screen shots to an online service, like Dropbox.com or Google Drive, and adding links to your mailing list posts, instead of attaching them. That way, everyone on the list does not have to download them.
apologies for that - I was just lazy.. the original file was anyhow blocked and you were the only one to receive it.. I will follow your suggestions in the future.
Thanks,
Teo
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130923/cc83c174/attachment.html>
