[Qgis-user] QGIS 2.0 - OSX - georeferencing plugin missing ?
Larry Shaffer larrys at dakotacarto.com
Mon Sep 23 13:10:35 PDT 2013
Hi Teo,
On Mon, Sep 23, 2013 at 1:25 PM, Teodoro Laino <teodoro.laino at gmail.com>wrote:
> Hi Larry,
> thanks for your reply - I'm running OSX 10.8.4 (and installed Mt.Lion
> version)
> I just followed your suggestions right now - I cleaned the
> /Application/QGIS folder (related to the night build) and installed a clean
> one from  kyngchaos.com.
> From the same website I installed
> GDAL Complete 1.10 framework package<http://www.kyngchaos.com/software/frameworks#gdal_complete>
> and also the python modules. Python 2.7 is installed (together with other
> version that I use for other stuff).
> After all that QGIS 2.0.1 is starting but Georeferencing is still not
> appearing (I have attached two snapshots, which I hope can go through the
> mailing list).
> I also do not have any error message when opening QGIS - so I basically
> have no idea what else to try.
> I would be glad to help to identify and reproduce the issue (at this stage
> we are at least in 2 to have this problem).
Thanks for your continued work on this. I'm beginning to think it may be a
difference between the kyngchaos.com GDAL_Complete release on 9-2 and the
one I am using for nightly builds, 8-19. Unfortunately, there is no direct
link to the previous version available (though I have both locally). I ran
both packge installers through Pacifist, and it looks like nothing is
missing in the latest, so...
I will see about testing some clean installs on a separate Mac here, today.
In the meantime, do you get any dylib error messages under the Plugins tab
in the View-->Panels-->Log Messages panel? This is where you may see errors
about loading C++ or Python plugins. Also, you can directly launch the QGIS
binary, embedded in the app bundle (<app>/Contents/MacOS/QGIS), in Terminal
and see if any errors show up in Terminal ouput.
Btw, you might consider uploading your screen shots to an online service,
like Dropbox.com or Google Drive, and adding links to your mailing list
posts, instead of attaching them. That way, everyone on the list does not
have to download them.
Regards,
Larry
> Best,
> Teo
> On Sep 23, 2013, at 7:27 PM, Larry Shaffer <larrys at dakotacarto.com> wrote:
> Hello Teo,
> On Mon, Sep 23, 2013 at 9:52 AM, Teodoro Laino <teodoro.laino at gmail.com>wrote:
>> well.. that's precisely my problem..
>> In the OSX build, in the Plugins -> manage and install plugins, there is
>> no "Georeferences GDAL"
>> ---8<------snip----
>> That's the reason I'm thinking that something must be screwed up with the
>> OSX build distribution. Or, again, something terribly obvious that I'm
>> missing..
> I just double-checked both 10.7-8 and 10.6 nightly builds and there are no
> issues with the 2.1 apps, with regards to the Georeferencer (that I can
> tell).
> However, I did notice that there was still a 2.0.1 app in the 10.6
> download archive folder (10.7-8 archive is fine). This happened during the
> switch from 1.9 to 2.0.1 to 2.1.0, and I forgot to prune it. If you have
> installed the 2.0.1 app, please remove it, as it is NOT a release
> distribution.
> It is unclear what Mac OS X version you are using. If you are running
> 10.7-8, download the 2.0.1 release installer from kyngchaos.com. Then
> please make sure to remove ANY accidental 2.0.1 nightly installed, as the
> Kyngchaos.com installer will try to install into that application bundle
> instead of /Applications (this is also noted in the README).
> If you are using Mac OS X 10.6, and are not needing to test the nightly
> builds, please wait until kyngchaos.com produces a 10.6 installer for the
> 2.0.1 branch. The nightlies are not 2.0.1 releases, but builds of the 2.1.0
> master branch.
> If the Georeferencer plugin still does not show up, then it is probably an
> issue with your supporting frameworks, which would need upgraded.
> Please report on success or failure, either way. Thanks.
> Regards,
> Larry Shaffer
> Dakota Cartography
> Black Hills, South Dakota
>> Teo
>> On Sep 23, 2013, at 5:33 PM, skampus <stefano.campus at regione.piemonte.it>
>> wrote:
>> > in Plugins-->manage and install plugins, check "Georeferencer GDAL"
>> > s.
>> > View this message in context:
>> http://osgeo-org.1560.x6.nabble.com/QGIS-2-0-OSX-georeferencing-plugin-missing-tp5079279p5079298.html
>> > Sent from the Quantum GIS - User mailing list archive at Nabble.com.
>> > _______________________________________________
>> > Qgis-user mailing list
>> > Qgis-user at lists.osgeo.org
>> > http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130923/41a29d70/attachment.html>
