[Qgis-user] Oracle - QGIS connection
Jonathan Moules
jonathanmoules at warwickshire.gov.uk
Tue Sep 24 09:16:19 PDT 2013
Hi Duarte,
Yep it works fine:
sqlplus username/password at co_gistest
Logs me straight in, and a trial select confirms I'm in.
It's just QGIS that is having issues.
My PATH (this is windows) is:
c:\admin\apps\oracle32\product\11.2.0\client_1\bin;%SystemRoot%\system32;%SystemRoot%;%SystemRoot%\System32\Wbem;%SYSTEMROOT%\System32\WindowsPowerShell\v1.0\;C:\Program
Files (x86)\Microsoft Application Virtualization Client;C:\Program Files
(x86)\ActivIdentity\SecureLogin\
Am very perplexed!
Cheers,
Jonathan
On 24 September 2013 17:05, Duarte Carreira <DCarreira at edia.pt> wrote:
> It could be environmental variables messed up when launching qgis… does
> sqlplus work?****
> Duarte****
> *De:* Jonathan Moules [mailto:jonathanmoules at warwickshire.gov.uk]
> *Enviada:* terça-feira, 24 de Setembro de 2013 16:00
> *Para:* qgis-user at lists.osgeo.org
> *Assunto:* Re: [Qgis-user] Oracle - QGIS connection****
> Hi List,****
> I've done a lot more dabbling and it simply refuses to work. I've now got
> to the point where I've installed the Administrator install of the Oracle
> client. Both QGIS and the client are 32bit. But no matter what I keep
> getting the Ora-12154 error.****
> If I try tnsping, it can resolve the name just fine, so I'm not clear why
> it is failing with QGIS.****
> I don't remember what I did previously to get it working but I'm sure it
> wasn't anything like this much trouble.****
> Anyone?****
> Thanks,****
> Jonathan****
> On 23 September 2013 12:56, Jonathan Moules <
> jonathanmoules at warwickshire.gov.uk> wrote:****
> Hi List,****
> This is happening in 2.0.1 too. As other things can connect to the
> database from this machine I have to guess that it is a QGIS thing. I know
> it worked previously but doesn't seem to any more.****
> Does it work for other folks? What are you entering into the parameters?**
> Thanks,****
> Jonathan****
> On 28 August 2013 14:33, Jonathan Moules <
> Anyone?****
> I'm using QGIS weekly build d61cb25 on windows 7.****
> Thanks,****
> Jonathan****
> This transmission is intended for the named addressee(s) only and may
> contain sensitive or protectively marked material up to RESTRICTED and
> should be handled accordingly. Unless you are the named addressee (or
> authorised to receive it for the addressee) you may not copy or use it, or
> disclose it to anyone else. If you have received this transmission in error
> please notify the sender immediately. All email traffic sent to or from us,
> including without limitation all GCSX traffic, may be subject to recording
> and/or monitoring in accordance with relevant legislation.****
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130924/fa0ca1ca/attachment.html>
