[Qgis-user] Oracle - QGIS connection
Jonathan Moules
jonathanmoules at warwickshire.gov.uk
Tue Sep 24 09:48:01 PDT 2013
Hi Duarte,
Cunning, I'd not played with the Python console before.
The QGIS path is the same as the system one, though with extra stuff
pre-pended - Oracle is in there just fine:
'c:\Admin\Apps\Progs\QGISDU~1\apps\grass\grass-6.4.3\bin;c:\Admin\Apps\Progs\QGISDU~1\apps\msys\bin;c:\Admin\Apps\Progs\QGISDU~1\bin;
> *c:\admin\apps\oracle32\product\11.2.0\client_1\bin*;C:\windows\system32;C:\windows;C:\windows\System32\Wbem;C:\windows\System32\WindowsPowerShell\v1.0\;C:\Program
> Files (x86)\Microsoft Application Virtualization Client;C:\Program Files
> (x86)\ActivIdentity\SecureLogin\;C:\Program
> Files\Intel\WiFi\bin\;C:\Program Files\Common
> Files\Intel\WirelessCommon\;c:\Admin\Apps\Progs\QGISDU~1\apps\msys\bin;c:\Admin\Apps\Progs\QGISDU~1\apps\Python27\Scripts;c:\Admin\Apps\Progs\QGISDU~1\apps\qgis\bin;c:\Admin\Apps\Progs\QGISDU~1\apps\grass\grass-6.4.3\lib'
Trying TNS ping from within QGIS worked just fine too:
> Attempting to contact (DESCRIPTION = (ADDRESS = (COMMUNITY = wcctcp.world)
> (PROTOCOL = TCP) (Host = co-gistest-li2) (Port = 1521)) (CONNECT_DATA =
> (SID = gistest) (GLOBAL_NAME = co_gistest.world)))
> OK (0 msec)
If I try and "cheat" and change my host from "co_gistest" to the actual
machine name: "co-gistest-li2" - I get back an ORA-12514 instead where it
says it doesn't know of the given host. But if I enter random gibberish it
goes back to a ORA-12154.
Very confusing (but it is Oracle).
Jonathan
On 24 September 2013 17:28, Duarte Carreira <DCarreira at edia.pt> wrote:
> Can you compare your path to what qgis is using?****
> In python console type:****
> import os****
> os.environ["PATH"]****
> It seems to me qgis is not finding your tns settings… your’re setting
> these up in tnsnames.ora?****
> You can try tnsping from qgis and see what happens… try print
> os.popen(“tnsping…”).read() in your python console…****
> Duarte****
> *De:* Jonathan Moules [mailto:jonathanmoules at warwickshire.gov.uk]
> *Enviada:* terça-feira, 24 de Setembro de 2013 17:16
> *Para:* Duarte Carreira
> *Cc:* qgis-user at lists.osgeo.org
> *Assunto:* Re: [Qgis-user] Oracle - QGIS connection****
> Hi Duarte,****
> Yep it works fine:****
> sqlplus username/password at co_gistest****
> Logs me straight in, and a trial select confirms I'm in.****
> It's just QGIS that is having issues.****
> My PATH (this is windows) is:****
> c:\admin\apps\oracle32\product\11.2.0\client_1\bin;%SystemRoot%\system32;%SystemRoot%;%SystemRoot%\System32\Wbem;%SYSTEMROOT%\System32\WindowsPowerShell\v1.0\;C:\Program
> (x86)\ActivIdentity\SecureLogin\****
> Am very perplexed!****
> Cheers,****
> Jonathan****
> On 24 September 2013 17:05, Duarte Carreira <DCarreira at edia.pt> wrote:****
> It could be environmental variables messed up when launching qgis… does
> sqlplus work?****
> Duarte****
> *Enviada:* terça-feira, 24 de Setembro de 2013 16:00
> *Para:* qgis-user at lists.osgeo.org
> Hi List,****
> I've done a lot more dabbling and it simply refuses to work. I've now got
> to the point where I've installed the Administrator install of the Oracle
> client. Both QGIS and the client are 32bit. But no matter what I keep
> getting the Ora-12154 error.****
> If I try tnsping, it can resolve the name just fine, so I'm not clear why
> it is failing with QGIS.****
> I don't remember what I did previously to get it working but I'm sure it
> wasn't anything like this much trouble.****
> Anyone?****
> Thanks,****
> Jonathan****
> On 23 September 2013 12:56, Jonathan Moules <
> jonathanmoules at warwickshire.gov.uk> wrote:****
> Hi List,****
> This is happening in 2.0.1 too. As other things can connect to the
> database from this machine I have to guess that it is a QGIS thing. I know
> it worked previously but doesn't seem to any more.****
> Does it work for other folks? What are you entering into the parameters?**
> Thanks,****
> Jonathan****
> On 28 August 2013 14:33, Jonathan Moules <
> Anyone?****
> I'm using QGIS weekly build d61cb25 on windows 7.****
> Thanks,****
> Jonathan****
> This transmission is intended for the named addressee(s) only and may
> contain sensitive or protectively marked material up to RESTRICTED and
> should be handled accordingly. Unless you are the named addressee (or
> authorised to receive it for the addressee) you may not copy or use it, or
> disclose it to anyone else. If you have received this transmission in error
> please notify the sender immediately. All email traffic sent to or from us,
> including without limitation all GCSX traffic, may be subject to recording
> and/or monitoring in accordance with relevant legislation.****
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130924/5bf8539b/attachment.html>
