[Qgis-user] Oracle - QGIS connection
Bob and Deb bobdebm at gmail.com
Tue Sep 24 10:14:59 PDT 2013
Hello Jonathan,
How about setting the environment variable ORACLE_HOME to
c:\admin\apps\oracle32\product\11.2.0\client_1 and TNS_ADMIN to the
location of the directory that contains tnsnames.ora?  That is what I did
and it works fine.  In the past I also had to rename the oci.dll (or you
can remove it) from c:\osgeo4w\bin because it conflicted with the oci.dll
in %ORACLE_HOME%.  Btw, we are connecting to Oracle 11.2.0 using OS
authentication.
Bob
On Tue, Sep 24, 2013 at 9:48 AM, Jonathan Moules <
jonathanmoules at warwickshire.gov.uk> wrote:
> Hi Duarte,
> Cunning, I'd not played with the Python console before.
> The QGIS path is the same as the system one, though with extra stuff
> pre-pended - Oracle is in there just fine:
>> 'c:\Admin\Apps\Progs\QGISDU~1\apps\grass\grass-6.4.3\bin;c:\Admin\Apps\Progs\QGISDU~1\apps\msys\bin;c:\Admin\Apps\Progs\QGISDU~1\bin;
>> *c:\admin\apps\oracle32\product\11.2.0\client_1\bin*;C:\windows\system32;C:\windows;C:\windows\System32\Wbem;C:\windows\System32\WindowsPowerShell\v1.0\;C:\Program
>> Files (x86)\Microsoft Application Virtualization Client;C:\Program Files
>> (x86)\ActivIdentity\SecureLogin\;C:\Program
>> Files\Intel\WiFi\bin\;C:\Program Files\Common
>> Files\Intel\WirelessCommon\;c:\Admin\Apps\Progs\QGISDU~1\apps\msys\bin;c:\Admin\Apps\Progs\QGISDU~1\apps\Python27\Scripts;c:\Admin\Apps\Progs\QGISDU~1\apps\qgis\bin;c:\Admin\Apps\Progs\QGISDU~1\apps\grass\grass-6.4.3\lib'
> Trying TNS ping from within QGIS worked just fine too:
>> Attempting to contact (DESCRIPTION = (ADDRESS = (COMMUNITY =
>> wcctcp.world) (PROTOCOL = TCP) (Host = co-gistest-li2) (Port = 1521))
>> (CONNECT_DATA = (SID = gistest) (GLOBAL_NAME = co_gistest.world)))
>> OK (0 msec)
> If I try and "cheat" and change my host from "co_gistest" to the actual
> machine name: "co-gistest-li2" - I get back an ORA-12514 instead where it
> says it doesn't know of the given host. But if I enter random gibberish it
> goes back to a ORA-12154.
> Very confusing (but it is Oracle).
> Jonathan
> On 24 September 2013 17:28, Duarte Carreira <DCarreira at edia.pt> wrote:
>>  Can you compare your path to what qgis is using?****
>> In python console type:****
>> import os****
>> os.environ["PATH"]****
>> It seems to me qgis is not finding your tns settings… your’re setting
>> these up in tnsnames.ora?****
>> You can try tnsping from qgis and see what happens… try  print
>> os.popen(“tnsping…”).read() in your python console…****
>> Duarte****
>> *De:* Jonathan Moules [mailto:jonathanmoules at warwickshire.gov.uk]
>> *Enviada:* terça-feira, 24 de Setembro de 2013 17:16
>> *Para:* Duarte Carreira
>> *Cc:* qgis-user at lists.osgeo.org
>> *Assunto:* Re: [Qgis-user] Oracle - QGIS connection****
>> Hi Duarte,****
>> Yep it works fine:****
>> sqlplus username/password at co_gistest****
>> Logs me straight in, and a trial select confirms I'm in.****
>> It's just QGIS that is having issues.****
>> My PATH (this is windows) is:****
>> c:\admin\apps\oracle32\product\11.2.0\client_1\bin;%SystemRoot%\system32;%SystemRoot%;%SystemRoot%\System32\Wbem;%SYSTEMROOT%\System32\WindowsPowerShell\v1.0\;C:\Program
>> (x86)\ActivIdentity\SecureLogin\****
>> Am very perplexed!****
>> Cheers,****
>> Jonathan****
>> On 24 September 2013 17:05, Duarte Carreira <DCarreira at edia.pt> wrote:***
>> It could be environmental variables messed up when launching qgis… does
>> sqlplus work?****
>> Duarte****
>> *Enviada:* terça-feira, 24 de Setembro de 2013 16:00
>> *Para:* qgis-user at lists.osgeo.org
>> Hi List,****
>> I've done a lot more dabbling and it simply refuses to work. I've now got
>> to the point where I've installed the Administrator install of the Oracle
>> client. Both QGIS and the client are 32bit. But no matter what I keep
>> getting the Ora-12154 error.****
>> If I try tnsping, it can resolve the name just fine, so I'm not clear why
>> it is failing with QGIS.****
>> I don't remember what I did previously to get it working but I'm sure it
>> wasn't anything like this much trouble.****
>> Anyone?****
>> Thanks,****
>> Jonathan****
>> On 23 September 2013 12:56, Jonathan Moules <
>> jonathanmoules at warwickshire.gov.uk> wrote:****
>> Hi List,****
>> This is happening in 2.0.1 too. As other things can connect to the
>> database from this machine I have to guess that it is a QGIS thing. I know
>> it worked previously but doesn't seem to any more.****
>> Does it work for other folks? What are you entering into the parameters?*
>> Thanks,****
>> Jonathan****
>> On 28 August 2013 14:33, Jonathan Moules <
>> Anyone?****
>> I'm using QGIS weekly build d61cb25 on windows 7.****
>> Thanks,****
>> Jonathan****
>> This transmission is intended for the named addressee(s) only and may
>> contain sensitive or protectively marked material up to RESTRICTED and
>> should be handled accordingly. Unless you are the named addressee (or
>> authorised to receive it for the addressee) you may not copy or use it, or
>> disclose it to anyone else. If you have received this transmission in error
>> please notify the sender immediately. All email traffic sent to or from us,
>> including without limitation all GCSX traffic, may be subject to recording
>> and/or monitoring in accordance with relevant legislation.****
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130924/a4a2dc95/attachment.html>
