[Qgis-user] Oracle - QGIS connection
Jonathan Moules jonathanmoules at warwickshire.gov.uk
Wed Sep 25 02:32:45 PDT 2013
Hi Bob,
Thanks for the reply. Unfortunately none of those things seems to have made
a difference.
I've now installed QGIS on a second machine, one that already has a working
Oracle administrator install that various other applications are
successfully using (i.e. FME). But QGIS on that machine has the exact same
problem with the exact same failure mechanisms/errors.
So the issue seems to be QGIS specific, but I don't know enough to be able
to report it as a useful bug report.
Cheers,
Jonathan
On 24 September 2013 18:14, Bob and Deb <bobdebm at gmail.com> wrote:
> Hello Jonathan,
> How about setting the environment variable ORACLE_HOME to
> c:\admin\apps\oracle32\product\11.2.0\client_1 and TNS_ADMIN to the
> location of the directory that contains tnsnames.ora?  That is what I did
> and it works fine.  In the past I also had to rename the oci.dll (or you
> can remove it) from c:\osgeo4w\bin because it conflicted with the oci.dll
> in %ORACLE_HOME%.  Btw, we are connecting to Oracle 11.2.0 using OS
> authentication.
> Bob
> On Tue, Sep 24, 2013 at 9:48 AM, Jonathan Moules <
> jonathanmoules at warwickshire.gov.uk> wrote:
>> Hi Duarte,
>> Cunning, I'd not played with the Python console before.
>> The QGIS path is the same as the system one, though with extra stuff
>> pre-pended - Oracle is in there just fine:
>>> 'c:\Admin\Apps\Progs\QGISDU~1\apps\grass\grass-6.4.3\bin;c:\Admin\Apps\Progs\QGISDU~1\apps\msys\bin;c:\Admin\Apps\Progs\QGISDU~1\bin;
>>> *c:\admin\apps\oracle32\product\11.2.0\client_1\bin*;C:\windows\system32;C:\windows;C:\windows\System32\Wbem;C:\windows\System32\WindowsPowerShell\v1.0\;C:\Program
>>> Files (x86)\Microsoft Application Virtualization Client;C:\Program Files
>>> (x86)\ActivIdentity\SecureLogin\;C:\Program
>>> Files\Intel\WiFi\bin\;C:\Program Files\Common
>>> Files\Intel\WirelessCommon\;c:\Admin\Apps\Progs\QGISDU~1\apps\msys\bin;c:\Admin\Apps\Progs\QGISDU~1\apps\Python27\Scripts;c:\Admin\Apps\Progs\QGISDU~1\apps\qgis\bin;c:\Admin\Apps\Progs\QGISDU~1\apps\grass\grass-6.4.3\lib'
>> Trying TNS ping from within QGIS worked just fine too:
>>> Attempting to contact (DESCRIPTION = (ADDRESS = (COMMUNITY =
>>> wcctcp.world) (PROTOCOL = TCP) (Host = co-gistest-li2) (Port = 1521))
>>> (CONNECT_DATA = (SID = gistest) (GLOBAL_NAME = co_gistest.world)))
>>> OK (0 msec)
>> If I try and "cheat" and change my host from "co_gistest" to the actual
>> machine name: "co-gistest-li2" - I get back an ORA-12514 instead where it
>> says it doesn't know of the given host. But if I enter random gibberish it
>> goes back to a ORA-12154.
>> Very confusing (but it is Oracle).
>> Jonathan
>> On 24 September 2013 17:28, Duarte Carreira <DCarreira at edia.pt> wrote:
>>>  Can you compare your path to what qgis is using?****
>>> In python console type:****
>>> import os****
>>> os.environ["PATH"]****
>>> It seems to me qgis is not finding your tns settings… your’re setting
>>> these up in tnsnames.ora?****
>>> You can try tnsping from qgis and see what happens… try  print
>>> os.popen(“tnsping…”).read() in your python console…****
>>> Duarte****
>>> *De:* Jonathan Moules [mailto:jonathanmoules at warwickshire.gov.uk]
>>> *Enviada:* terça-feira, 24 de Setembro de 2013 17:16
>>> *Para:* Duarte Carreira
>>> *Cc:* qgis-user at lists.osgeo.org
>>> *Assunto:* Re: [Qgis-user] Oracle - QGIS connection****
>>> Hi Duarte,****
>>> Yep it works fine:****
>>> sqlplus username/password at co_gistest****
>>> Logs me straight in, and a trial select confirms I'm in.****
>>> It's just QGIS that is having issues.****
>>> My PATH (this is windows) is:****
>>> c:\admin\apps\oracle32\product\11.2.0\client_1\bin;%SystemRoot%\system32;%SystemRoot%;%SystemRoot%\System32\Wbem;%SYSTEMROOT%\System32\WindowsPowerShell\v1.0\;C:\Program
>>> (x86)\ActivIdentity\SecureLogin\****
>>> Am very perplexed!****
>>> Cheers,****
>>> Jonathan****
>>> On 24 September 2013 17:05, Duarte Carreira <DCarreira at edia.pt> wrote:**
>>> It could be environmental variables messed up when launching qgis… does
>>> sqlplus work?****
>>> Duarte****
>>> *Enviada:* terça-feira, 24 de Setembro de 2013 16:00
>>> *Para:* qgis-user at lists.osgeo.org
>>> Hi List,****
>>> I've done a lot more dabbling and it simply refuses to work. I've now
>>> got to the point where I've installed the Administrator install of the
>>> Oracle client. Both QGIS and the client are 32bit. But no matter what I
>>> keep getting the Ora-12154 error.****
>>> If I try tnsping, it can resolve the name just fine, so I'm not clear
>>> why it is failing with QGIS.****
>>> I don't remember what I did previously to get it working but I'm sure it
>>> wasn't anything like this much trouble.****
>>> Anyone?****
>>> Thanks,****
>>> Jonathan****
>>> On 23 September 2013 12:56, Jonathan Moules <
>>> jonathanmoules at warwickshire.gov.uk> wrote:****
>>> Hi List,****
>>> This is happening in 2.0.1 too. As other things can connect to the
>>> database from this machine I have to guess that it is a QGIS thing. I know
>>> it worked previously but doesn't seem to any more.****
>>> Does it work for other folks? What are you entering into the parameters?
>>> Thanks,****
>>> Jonathan****
>>> On 28 August 2013 14:33, Jonathan Moules <
>>> Anyone?****
>>> I'm using QGIS weekly build d61cb25 on windows 7.****
>>> Thanks,****
>>> Jonathan****
>>> This transmission is intended for the named addressee(s) only and may
>>> contain sensitive or protectively marked material up to RESTRICTED and
>>> should be handled accordingly. Unless you are the named addressee (or
>>> authorised to receive it for the addressee) you may not copy or use it, or
>>> disclose it to anyone else. If you have received this transmission in error
>>> please notify the sender immediately. All email traffic sent to or from us,
>>> including without limitation all GCSX traffic, may be subject to recording
>>> and/or monitoring in accordance with relevant legislation.****
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130925/4ab62372/attachment.html>
