[Qgis-user] Print composer & HTML labels
Julian Bogdani jbogdani at gmail.com
Wed Sep 25 02:07:27 PDT 2013
Hello all,
I have a problem with exporting print composers with HTML labels on MacOS 10.6.8; I don't know if this is affecting other OS.
I'm not able to export (image, pdf, svg, etc) a layout containing a text label rendered as HTML: the dialog with the export location and confirmation appears for a bout a second or less and then disappears.
If I disable the "render as HTML" option everything works fine.
Julian Bogdani
http://bradypus.net
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130925/da2e65ae/attachment.html>
