[Qgis-user] Sextante Modeler - r.reclass problem?
ALT SHN
i.geografica at alt-shn.org
Wed Sep 25 10:27:00 PDT 2013
Thank you Victor,
With "new thread" off, QGIS does not freeze, but the model does not finish
the analysis.
Anyway, appart from the Graphical Modeler, SEXTANTE is much more stable and
usable!
And will undoubtedly became a major thing - thanks Victor!
Regards,
2013/9/25 Victor Olaya <volayaf at gmail.com>
> There is a known bug in windows with models freezing the UI. Can you
> try going to the configuration and setting the "Run algorithms in a
> different thread" option to off? That usually helps
> Cheers
> VIctor
> 2013/9/25 ALT SHN <i.geografica at alt-shn.org>:
> > Hi,
> > I've been testing Sextante toolbox in QGIS 2.0.1 (from OSGEO4W
> installer),
> > and for the most part it seems to be ok, However i've come to a problem
> that
> > always causes qgis to freeze (not-responding state).
> > This happens if I use r.reclass in my model. Can anyone please give it a
> try
> > using the model attached to this message?
> > (Win7 64bits)
> > Thanks
> > SOCIEDADE DE HISTÓRIA NATURAL - Departamento de Informação Geográfica
> > Apartado 25 2564-909 Torres Vedras Portugal
> > Sede e Biblioteca: rua Cavaleiros da Espora Dourada, 27A 2560 Torres
> Vedras
> > Laboratório de Paleontologia e Paleoecologia: Polígono Industrial do
> Alto do
> > Ameal 2565-641 Ramalhal
> > http://alt-shn.blogspot.com
> > www.alt-shn.org
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-user
Sede e Biblioteca: rua Cavaleiros da Espora Dourada, 27A 2560 Torres Vedras
Laboratório de Paleontologia e Paleoecologia: Polígono Industrial do Alto
do Ameal 2565-641 Ramalhal
www.alt-shn.org
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130925/f89a9ff1/attachment.html>
