[Qgis-user] Sextante Modeler - r.reclass problem?
Victor Olaya
volayaf at gmail.com
Wed Sep 25 10:47:57 PDT 2013
Could you send the error log or give some more information about what
it does? Also, the reclass algorithm works when used outside the
modeler?
I will try to test it know here.
Thanks!
2013/9/25 ALT SHN <i.geografica at alt-shn.org>:
> Thank you Victor,
> With "new thread" off, QGIS does not freeze, but the model does not finish
> the analysis.
> Anyway, appart from the Graphical Modeler, SEXTANTE is much more stable and
> usable!
> And will undoubtedly became a major thing - thanks Victor!
> Regards,
> 2013/9/25 Victor Olaya <volayaf at gmail.com>
>> There is a known bug in windows with models freezing the UI. Can you
>> try going to the configuration and setting the "Run algorithms in a
>> different thread" option to off? That usually helps
>> Cheers
>> VIctor
>> > Hi,
>> > I've been testing Sextante toolbox in QGIS 2.0.1 (from OSGEO4W
>> > installer),
>> > and for the most part it seems to be ok, However i've come to a problem
>> > that
>> > always causes qgis to freeze (not-responding state).
>> > This happens if I use r.reclass in my model. Can anyone please give it a
>> > try
>> > using the model attached to this message?
>> > (Win7 64bits)
>> > Thanks
>> > SOCIEDADE DE HISTÓRIA NATURAL - Departamento de Informação Geográfica
>> > Apartado 25 2564-909 Torres Vedras Portugal
>> > Sede e Biblioteca: rua Cavaleiros da Espora Dourada, 27A 2560 Torres
>> > Vedras
>> > Laboratório de Paleontologia e Paleoecologia: Polígono Industrial do
>> > Alto do
>> > Ameal 2565-641 Ramalhal
>> > http://alt-shn.blogspot.com
>> > www.alt-shn.org
>> > _______________________________________________
>> > Qgis-user mailing list
>> > Qgis-user at lists.osgeo.org
>> > http://lists.osgeo.org/mailman/listinfo/qgis-user
> Sede e Biblioteca: rua Cavaleiros da Espora Dourada, 27A 2560 Torres Vedras
> Laboratório de Paleontologia e Paleoecologia: Polígono Industrial do Alto do
> www.alt-shn.org
