[Qgis-user] Problems with Shapely instalation, using the Console
Paulo Gali Macedo pgmacedo at fc.up.pt
Sat Sep 28 17:49:10 PDT 2013
Hi Everybody,
I ' m a newcomer to QGIS and I'm finding so
problems in running some of its plugins.
Thanks to some of you, I have already made some progress.
Now, I have Qgis 2.0.1 - Dufour, running on a
MacBook Pro with OSX 10.6.8 (Snow Leopard).
However, on trying to load the "Contour" Plugin, I'm still finding dificulties.
Apparently, a Python Plugin called Shapely is missing.
I found two versions of it in the net, and on
trying to setup Shapely, using the  Console I now
get the message below.
Can anybody help me ?
On waiting for your answers, I thank you all in advance.
All the Best.
Paulo Gali
Console setup trial for Shapely:
Last login: Sat Sep 28 19:21:22 on console
MBproPGMacedo-5:~ pgmacedo$ cd /Users/pgmacedo/Desktop/Shapely-1.2.16/
MBproPGMacedo-5:Shapely-1.2.16 pgmacedo$
LDFLAGS=`/Library/Frameworks/GEOS.framework/Versions/3/unix/bin/geos-config
--libs`
CFLAGS=`/Library/Frameworks/GEOS.framework/Versions/3/unix/bin/geos-config
--cflags`
MBproPGMacedo-5:Shapely-1.2.16 pgmacedo$ python setup.py install
setup.py:9: Warning: Failed to import
distribute_setup, continuing without distribute.
   Warning)
   File "setup.py", line 16, in <module>
     from setuptools.extension import Extension
ImportError: No module named setuptools.extension
-c 'import osgeo; print osgeo.__version__'
   File "<string>", line 1, in <module>
ImportError: No module named osgeo
MBproPGMacedo-5:Shapely-1.2.16 pgmacedo$ cd
/Users/pgmacedo/Desktop/Shapely-1.2.18/
MBproPGMacedo-5:Shapely-1.2.18 pgmacedo$
--libs`
--cflags`
MBproPGMacedo-5:Shapely-1.2.18 pgmacedo$ python setup.py install
   Warning)
   File "setup.py", line 17, in <module>
Prof. Paulo Gali Macedo
Departamento de FĂ­sica e Astronomia
Faculdade de Ciencias da Universidade do Porto
R. do Campo Alegre,  687
4169-007 Porto
         PORTUGAL
_________________
Tel . (+351)-220402854
HOME ADRESS:
  R. Hernani Torres, 39 - 7 Esq.
4200-320  Porto
         PORTUGAL
Home Tel .  (+351)-225021945
TM.    	   (+351)-965871512
e-mail:
<mailto:pgmacedo at fc.up.pt>pgmacedo at fc.up.pt
