[Qgis-user] Problems with Shapely instalation, using the Console
Noli Sicad
nsicad at gmail.com
Sat Sep 28 18:27:36 PDT 2013
Hi Paulo,
Try to install setuptools (below), it might solve the problem.
https://pypi.python.org/pypi/setuptools
Noli
On 9/29/13, Paulo Gali Macedo <pgmacedo at fc.up.pt> wrote:
> Hi Everybody,
> I ' m a newcomer to QGIS and I'm finding so
> problems in running some of its plugins.
> Thanks to some of you, I have already made some progress.
> Now, I have Qgis 2.0.1 - Dufour, running on a
> MacBook Pro with OSX 10.6.8 (Snow Leopard).
> However, on trying to load the "Contour" Plugin, I'm still finding
> dificulties.
> Apparently, a Python Plugin called Shapely is missing.
> I found two versions of it in the net, and on
> trying to setup Shapely, using the Console I now
> get the message below.
> Can anybody help me ?
> On waiting for your answers, I thank you all in advance.
> All the Best.
> Paulo Gali
> Console setup trial for Shapely:
> Last login: Sat Sep 28 19:21:22 on console
> MBproPGMacedo-5:~ pgmacedo$ cd /Users/pgmacedo/Desktop/Shapely-1.2.16/
> MBproPGMacedo-5:Shapely-1.2.16 pgmacedo$
> LDFLAGS=`/Library/Frameworks/GEOS.framework/Versions/3/unix/bin/geos-config
> --libs`
> CFLAGS=`/Library/Frameworks/GEOS.framework/Versions/3/unix/bin/geos-config
> --cflags`
> MBproPGMacedo-5:Shapely-1.2.16 pgmacedo$ python setup.py install
> setup.py:9: Warning: Failed to import
> distribute_setup, continuing without distribute.
> Warning)
> Traceback (most recent call last):
> File "setup.py", line 16, in <module>
> from setuptools.extension import Extension
> ImportError: No module named setuptools.extension
> -c 'import osgeo; print osgeo.__version__'
> File "<string>", line 1, in <module>
> ImportError: No module named osgeo
> MBproPGMacedo-5:Shapely-1.2.16 pgmacedo$ cd
> /Users/pgmacedo/Desktop/Shapely-1.2.18/
> MBproPGMacedo-5:Shapely-1.2.18 pgmacedo$
> --libs`
> --cflags`
> MBproPGMacedo-5:Shapely-1.2.18 pgmacedo$ python setup.py install
> Warning)
> File "setup.py", line 17, in <module>
> Prof. Paulo Gali Macedo
> Departamento de FĂsica e Astronomia
> Faculdade de Ciencias da Universidade do Porto
> R. do Campo Alegre, 687
> 4169-007 Porto
> PORTUGAL
> _________________
> Tel . (+351)-220402854
> HOME ADRESS:
> R. Hernani Torres, 39 - 7 Esq.
> 4200-320 Porto
> PORTUGAL
> Home Tel . (+351)-225021945
> TM. (+351)-965871512
> e-mail:
> <mailto:pgmacedo at fc.up.pt>pgmacedo at fc.up.pt
> Qgis-user mailing list
