[Qgis-user] Private copy of qgis.db and a problem with the public key
Levente
leventelist at gmail.com
Mon Sep 30 06:19:02 PDT 2013
You should insert "sudo", as indicated in the original line on the website.
Since I don't use sudo, I don't know how to do it by hart.
Levente
On Mon, Sep 30, 2013 at 2:45 PM, Giacomo Fontanelli <
giacomofontanelli76 at gmail.com> wrote:
> By now I still continue to obtain the error message
> The line sudo gpg --recv-key BBA6491F47765B75 is ok, but when I insert
> the command sudo gpg --export --armor BBA6491F47765B75 | apt-key add - I
> obtain the message "This command can only be used by root"
> Thank you
> On Sat, Sep 28, 2013 at 8:20 PM, Levente Kovacs <leventelist at gmail.com>wrote:
>> -----BEGIN PGP SIGNED MESSAGE-----
>> Hash: SHA1
>> On Sat, 28 Sep 2013 14:13:40 +0200
>> Paolo Cavallini <cavallini-h12OV65+u/41GQ1Ptb7lUw at public.gmane.org>
>> > Hash: SHA1
>> > Il 28/09/2013 13:33, Giacomo Fontanelli ha scritto:
>> > > 1) each time I start qgis 2.0 on my pc with Lubuntu 13.04 I get an
>> > > error message: COPIA PRIVATA DI QGIS.DB NON RIUSCITA (PRIVATE COPY
>> > > OF QGIS.DB NOT GOOD).
>> > know bug, fixed yesterday
>> However, the old/wrong (?) private key 997D3880 is listed here:
>> www.qgis.org/en/site/forusers/alldownloads.html
>> The correct(?) commands are:
>> You can insert the sudo thing which I don't want.
>> cheers and 73!
>> Levente
>> -----BEGIN PGP SIGNATURE-----
>> Version: GnuPG v1.4.12 (GNU/Linux)
>> iQEcBAEBAgAGBQJSRx4EAAoJECHeg32hsZ8o/IkH/2pAAOapDJykhixUrgwj5e/W
>> O3C3crxEOL9dVJFLCMmYjS3i5JiCBwKNX1lYd1lF7k3yrMnfc2Lt94I0N6BMnFfX
>> xcw/tzB+mlrXaXMC68Je/9cvEkIpd4BFDE6zQjpmk9G8lLviGZsrcJzahYGtK7vC
>> 2xks2Wvnbp0x3K4fFiVB99NTO+edOU7zKIZZjU7TFD54sxyjUp9hSxjiWoC/Upva
>> kuIFl7WvrS0A74+FfZ7Dw8P6g4qFr6xb+qsBXSRyizGoqHg+9rlCXv8047NjxXtE
>> avWH2m2cKaRDt6sM+ZN2I250wBnIGnUrEHjv2e7RkrW8qIEN6ebUQ+Tu5/pNC1c=
>> =2DVa
>> -----END PGP SIGNATURE-----
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130930/6cd836f0/attachment.html>
