[Qgis-user] Private copy of qgis.db and a problem with the public key
. digitalmaps at cox.net
Mon Sep 30 06:31:26 PDT 2013
On 9/30/2013 8:19 AM, Levente wrote:
> You should insert "sudo", as indicated in the original line on the
> website. Since I don't use sudo, I don't know how to do it by hart.
> Levente
> On Mon, Sep 30, 2013 at 2:45 PM, Giacomo Fontanelli
> <giacomofontanelli76 at gmail.com <mailto:giacomofontanelli76 at gmail.com>>
> wrote:
>     By now I still continue to obtain the error message
>     The line sudo gpg --recv-key BBA6491F47765B75 is ok, but when I
>     insert the command sudo gpg --export --armor BBA6491F47765B75 |
>     apt-key add - I obtain the message "This command can only be used
>     by root"
>     Thank you
>     On Sat, Sep 28, 2013 at 8:20 PM, Levente Kovacs
>     <leventelist at gmail.com <mailto:leventelist at gmail.com>> wrote:
>         -----BEGIN PGP SIGNED MESSAGE-----
>         Hash: SHA1
>         On Sat, 28 Sep 2013 14:13:40 +0200
>         Paolo Cavallini
>         <cavallini-h12OV65+u/41GQ1Ptb7lUw at public.gmane.org
>         > Hash: SHA1
>         > Il 28/09/2013 13:33, Giacomo Fontanelli ha scritto:
>         > > 1) each time I start qgis 2.0 on my pc with Lubuntu 13.04
>         I get an
>         > > error message: COPIA PRIVATA DI QGIS.DB NON RIUSCITA
>         (PRIVATE COPY
>         > > OF QGIS.DB NOT GOOD).
>         > know bug, fixed yesterday
>         However, the old/wrong (?) private key 997D3880 is listed here:
>         www.qgis.org/en/site/forusers/alldownloads.html
>         <http://www.qgis.org/en/site/forusers/alldownloads.html>
>         The correct(?) commands are:
>         gpg --export --armor BBA6491F47765B75 | apt-key add -
>         You can insert the sudo thing which I don't want.
>         cheers and 73!
>         Levente
>         -----BEGIN PGP SIGNATURE-----
>         Version: GnuPG v1.4.12 (GNU/Linux)
>         iQEcBAEBAgAGBQJSRx4EAAoJECHeg32hsZ8o/IkH/2pAAOapDJykhixUrgwj5e/W
>         O3C3crxEOL9dVJFLCMmYjS3i5JiCBwKNX1lYd1lF7k3yrMnfc2Lt94I0N6BMnFfX
>         xcw/tzB+mlrXaXMC68Je/9cvEkIpd4BFDE6zQjpmk9G8lLviGZsrcJzahYGtK7vC
>         2xks2Wvnbp0x3K4fFiVB99NTO+edOU7zKIZZjU7TFD54sxyjUp9hSxjiWoC/Upva
>         kuIFl7WvrS0A74+FfZ7Dw8P6g4qFr6xb+qsBXSRyizGoqHg+9rlCXv8047NjxXtE
>         avWH2m2cKaRDt6sM+ZN2I250wBnIGnUrEHjv2e7RkrW8qIEN6ebUQ+Tu5/pNC1c=
>         =2DVa
>         -----END PGP SIGNATURE-----
>         _______________________________________________
>         Qgis-user mailing list
>         Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>         http://lists.osgeo.org/mailman/listinfo/qgis-user
I'm not a Linux wonk.
Since you are using two commands on the same line joined by a pipe, "|",
you might need a second "sudo" after the pipe.
Also, try entering "sudo" and the password first. Then enter your
commands normally..
Heck, why don't you just go superuser and enter the commands.? Come on,
show that computer who is boss!
Stay Frosty!
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130930/1993ca53/attachment.html>
