[Qgis-user] Help reproducing a bug with Fix shapefile Encoding Plugin and Openlayers plugin - W7 - QGIS 2.0.1
Raúl Nanclares
raulnanclares at gmail.com
Mon Sep 30 11:06:02 PDT 2013
Hi everybody,
i need somebody to confirm there's a bug in the Fix Shapefile Encofing
Plugin.
Steps to reproduce:
1. Add an openlayers layer using the plugin.
2. Add a shapefile.
3. Try changing the shapefile encoding using the pluging mentioned above.
4. Get python Error:
An error has occured while executing Python code:
File
"C:\Users\user/.qgis2/python/plugins\shapefile_encoding_fixer\encoding_fixer_plugin.py",
line 311, in runAndClose
self.run()
File
line 321, in run
if self.layerSource( self.iface.mapCanvas().layer(i) ) ==
self.shapefileName:
File
line 200, in layerSource
srcPath = layer.dataProvider().dataSourceUri().split('|')[0]
AttributeError: 'OpenlayersLayer' object has no attribute 'dataProvider'
Python version:
2.7.4 (default, Apr 6 2013, 19:54:46) [MSC v.1500 32 bit (Intel)]
QGIS version:
2.0.1-Dufour Dufour, 34139bc
Thanks!
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130930/a7fc947e/attachment.html>
