[Qgis-user] Help reproducing a bug with Fix shapefile Encoding Plugin and Openlayers plugin - W7 - QGIS 2.0.1
Goyo
goyodiaz at gmail.com
Mon Sep 30 11:34:24 PDT 2013
2013/9/30 Raúl Nanclares <raulnanclares at gmail.com>:
> Hi everybody,
> i need somebody to confirm there's a bug in the Fix Shapefile Encofing
> Plugin.
> Steps to reproduce:
> Add an openlayers layer using the plugin.
> Add a shapefile.
> Try changing the shapefile encoding using the pluging mentioned above.
> Get python Error:
> An error has occured while executing Python code:
> Traceback (most recent call last):
> File
> "C:\Users\user/.qgis2/python/plugins\shapefile_encoding_fixer\encoding_fixer_plugin.py",
> line 311, in runAndClose
> self.run()
> File
> line 321, in run
> if self.layerSource( self.iface.mapCanvas().layer(i) ) ==
> self.shapefileName:
> File
> line 200, in layerSource
> srcPath = layer.dataProvider().dataSourceUri().split('|')[0]
> AttributeError: 'OpenlayersLayer' object has no attribute 'dataProvider'
I can replicate this in master.
Goyo
