[Qgis-user] QGIS in a virtual environment
Erivelton Guedes eriveltonguedes at gmail.com
Mon Sep 30 12:09:49 PDT 2013
Hi Ross,
yes, we have a 1.8 version in a Windows 2008 server with remote access
since 1 year ago. It works fine.
Best regards,
Erivelton
Hello list,
Has anyone had experience installing QGIS in a virtual environment, either
on a virtual desktop or as a virtual application, that they would be
willing to share?
We have a Windows Server environment with Citrix.
Thanks
Ross
Atenciosamente,
Erivelton Pires Guedes -
http://sitraer.sbta.org.br/
http://mapas.ipea.gov.br
21-8136-8680   (Tim)
Instituto de Pesquisa Econômica Aplicada (Ipea) - (61) 3515-8548
http://www.ipea.gov.br
http://www.sbta.org.br
http://eriveltonguedes.googlepages.com/
On Mon, Sep 30, 2013 at 4:00 PM, <qgis-user-request at lists.osgeo.org> wrote:
> Send Qgis-user mailing list submissions to
>         qgis-user at lists.osgeo.org
> To subscribe or unsubscribe via the World Wide Web, visit
>         http://lists.osgeo.org/mailman/listinfo/qgis-user
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
>         qgis-user-owner at lists.osgeo.org
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of Qgis-user digest..."
> Today's Topics:
>    1. QGIS in a virtual environment (Ross McDonald)
>    2. Re: Private copy of qgis.db and a problem with the        public key
>       (Levente)
>    3. Re: Private copy of qgis.db and a problem with the public key (.)
>    4. Editing capabilities (bug?) (Ant?nio M. Rodrigues)
>    5. Re: Editing capabilities (bug?) (Bernhard Str?bl)
>    6. Re: Editing capabilities (bug?) (Ant?nio M. Rodrigues)
>    7. Re: Editing capabilities (bug?) (J?rgen E. Fischer)
>    8. Re: Authentication in QGIS Server (WFS Service) (Antonio Vico)
>    9. Re: Authentication in QGIS Server (WFS Service) (Paolo Cavallini)
>   10. Help reproducing a bug with Fix shapefile Encoding Plugin and
>       Openlayers plugin - W7 - QGIS 2.0.1 (Ra?l Nanclares)
>   11. Re: Help reproducing a bug with Fix shapefile Encoding Plugin
>       and Openlayers plugin - W7 - QGIS 2.0.1 (Goyo)
> Message: 1
> Date: Mon, 30 Sep 2013 13:59:04 +0100
> From: "Ross McDonald" <ross at mixedbredie.net>
> To: qgis-user at lists.osgeo.org
> Subject: [Qgis-user] QGIS in a virtual environment
> Message-ID:
>         <e246b0b4a92caf68114da28019f4e4d2.squirrel at post.mixedbredie.net>
> Content-Type: text/plain;charset=iso-8859-1
> Hello list,
> willing to share?
> Thanks
> Ross
> Message: 2
> Date: Mon, 30 Sep 2013 15:19:02 +0200
> From: Levente <leventelist at gmail.com>
> To: Giacomo Fontanelli <giacomofontanelli76 at gmail.com>
> Cc: qgis-user at lists.osgeo.org
> Subject: Re: [Qgis-user] Private copy of qgis.db and a problem with
>         the     public key
> Message-ID:
> CACwWb3CY1nesXttkH_JxyGaW4zYGRL-fa0wrdOrcK5ykU0ekSg at mail.gmail.com>
> Content-Type: text/plain; charset="iso-8859-1"
> You should insert "sudo", as indicated in the original line on the website.
> Since I don't use sudo, I don't know how to do it by hart.
> Levente
> On Mon, Sep 30, 2013 at 2:45 PM, Giacomo Fontanelli <
> giacomofontanelli76 at gmail.com> wrote:
> > By now I still continue to obtain the error message
> > The line sudo gpg --recv-key BBA6491F47765B75 is ok, but when I insert
> > the command sudo gpg --export --armor BBA6491F47765B75 | apt-key add - I
> > obtain the message "This command can only be used by root"
> > Thank you
> > On Sat, Sep 28, 2013 at 8:20 PM, Levente Kovacs <leventelist at gmail.com
> >wrote:
> >> -----BEGIN PGP SIGNED MESSAGE-----
> >> Hash: SHA1
> >> On Sat, 28 Sep 2013 14:13:40 +0200
> >> Paolo Cavallini <cavallini-h12OV65+u/41GQ1Ptb7lUw at public.gmane.org>
> >> > Hash: SHA1
> >> > Il 28/09/2013 13:33, Giacomo Fontanelli ha scritto:
> >> > > 1) each time I start qgis 2.0 on my pc with Lubuntu 13.04 I get an
> >> > > error message: COPIA PRIVATA DI QGIS.DB NON RIUSCITA (PRIVATE COPY
> >> > > OF QGIS.DB NOT GOOD).
> >> > know bug, fixed yesterday
> >> However, the old/wrong (?) private key 997D3880 is listed here:
> >> www.qgis.org/en/site/forusers/alldownloads.html
> >> The correct(?) commands are:
> >> You can insert the sudo thing which I don't want.
> >> cheers and 73!
> >> Levente
> >> -----BEGIN PGP SIGNATURE-----
> >> Version: GnuPG v1.4.12 (GNU/Linux)
> >> iQEcBAEBAgAGBQJSRx4EAAoJECHeg32hsZ8o/IkH/2pAAOapDJykhixUrgwj5e/W
> >> O3C3crxEOL9dVJFLCMmYjS3i5JiCBwKNX1lYd1lF7k3yrMnfc2Lt94I0N6BMnFfX
> >> xcw/tzB+mlrXaXMC68Je/9cvEkIpd4BFDE6zQjpmk9G8lLviGZsrcJzahYGtK7vC
> >> 2xks2Wvnbp0x3K4fFiVB99NTO+edOU7zKIZZjU7TFD54sxyjUp9hSxjiWoC/Upva
> >> kuIFl7WvrS0A74+FfZ7Dw8P6g4qFr6xb+qsBXSRyizGoqHg+9rlCXv8047NjxXtE
> >> avWH2m2cKaRDt6sM+ZN2I250wBnIGnUrEHjv2e7RkrW8qIEN6ebUQ+Tu5/pNC1c=
> >> =2DVa
> >> -----END PGP SIGNATURE-----
> >> _______________________________________________
> >> Qgis-user at lists.osgeo.org
> -------------- next part --------------
> An HTML attachment was scrubbed...
> URL: <
> http://lists.osgeo.org/pipermail/qgis-user/attachments/20130930/6cd836f0/attachment-0001.html
> Message: 3
> Date: Mon, 30 Sep 2013 08:31:26 -0500
> From: "." <digitalmaps at cox.net>
>         the public key
> Message-ID: <52497D2E.4080709 at cox.net>
> Content-Type: text/plain; charset="iso-8859-1"; Format="flowed"
> > website. Since I don't use sudo, I don't know how to do it by hart.
> > Levente
> > <giacomofontanelli76 at gmail.com <mailto:giacomofontanelli76 at gmail.com>>
> >     insert the command sudo gpg --export --armor BBA6491F47765B75 |
> >     apt-key add - I obtain the message "This command can only be used
> >     by root"
> >     Thank you
> >         Hash: SHA1
> >         Paolo Cavallini
> >         > Hash: SHA1
> >         I get an
> >         (PRIVATE COPY
> >         <http://www.qgis.org/en/site/forusers/alldownloads.html>
> >         cheers and 73!
> >         Levente
> >         =2DVa
> >         Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
> I'm not a Linux wonk.
> Since you are using two commands on the same line joined by a pipe, "|",
> you might need a second "sudo" after the pipe.
> Also, try entering "sudo" and the password first. Then enter your
> commands normally..
> Heck, why don't you just go superuser and enter the commands.? Come on,
> show that computer who is boss!
> Stay Frosty!
> URL: <
> http://lists.osgeo.org/pipermail/qgis-user/attachments/20130930/1993ca53/attachment-0001.html
> Message: 4
> Date: Mon, 30 Sep 2013 15:06:23 +0100
> From: Ant?nio M. Rodrigues <amcrgrodrigues at gmail.com>
> To: "qgis-user at lists.osgeo.org" <qgis-user at lists.osgeo.org>
> Subject: [Qgis-user] Editing capabilities (bug?)
> Message-ID:
> CAC+EZtTdQBYdjG3fh+nzttw23H_hc16qjuUfuHROi5STQL-MRQ at mail.gmail.com>
> Hi all,
> I believe this might be a bug.
> After adding a shpapefile to qgis, "toggle editing" is active.
> After using the query tool to view only a selection of fectures, "toggle
> editing" ceases to be active, even after clearing the query expression.
> In this cases I have to remove the layer and add the shapefile again.
> Can other users, particularly on windows or mac, confirm this behaviour?
> OS: ubuntu 12.04.
> qgis2.01
> URL: <
> http://lists.osgeo.org/pipermail/qgis-user/attachments/20130930/f268a91d/attachment-0001.html
> Message: 5
> Date: Mon, 30 Sep 2013 16:19:06 +0200
> From: Bernhard Str?bl <bernhard.stroebl at jena.de>
> Subject: Re: [Qgis-user] Editing capabilities (bug?)
> Message-ID: <5249885A.7020704 at jena.de>
> Content-Type: text/plain; charset=ISO-8859-1; format=flowed
> hi,
> not confirmed using the filter on a local shape file
> neither on Win7 with QGIS 2.0.1 (64 bit) nor on OpenSuse 64bit
> you have do deactivate and reactivate the layer before toggle editing
> becomes active again.
> Bernhard
> Am 30.09.2013 16:06, schrieb Ant?nio M. Rodrigues:
> > Hi all,
> > OS: ubuntu 12.04.
> > qgis2.01
> > __________ Information from ESET Mail Security, version of virus
> signature database 8859 (20130930) __________
> > The message was checked by ESET Mail Security.
> > http://www.eset.com
> > http://www.eset.com
> __________ Information from ESET Mail Security, version of virus signature
> http://www.eset.com
> Message: 6
> Date: Mon, 30 Sep 2013 15:22:31 +0100
> To: Bernhard Str?bl <bernhard.stroebl at jena.de>
> Cc: "qgis-user at lists.osgeo.org" <qgis-user at lists.osgeo.org>
> Message-ID:
> CAC+EZtS7TLzty_oqczLjDLJxEmPUsyMUrtxwSqBqk3qEbcanQQ at mail.gmail.com>
> Ok, that's correct.
> Sorry, should have explored better.
> 2013/9/30 Bernhard Str?bl <bernhard.stroebl at jena.de>
> > hi,
> > Bernhard
> >> Hi all,
> >> OS: ubuntu 12.04.
> >> qgis2.01
> >> http://www.eset.com
> >> ______________________________**_________________
> >> http://lists.osgeo.org/**mailman/listinfo/qgis-user<
> http://lists.osgeo.org/mailman/listinfo/qgis-user>
> >> http://www.eset.com
> signature
> > http://www.eset.com
> URL: <
> http://lists.osgeo.org/pipermail/qgis-user/attachments/20130930/b53fada3/attachment-0001.html
> Message: 7
> Date: Mon, 30 Sep 2013 16:35:53 +0200
> From: J?rgen E. Fischer <jef at norbit.de>
> Message-ID: <20130930143553.GB9219 at norbit.de>
> Content-Type: text/plain; charset=iso-8859-1
> Hi Ant?nio,
> It's a OGR restriction. See http://hub.qgis.org/issues/2951.
> J?rgen
> J?rgen E. Fischer         norBIT GmbH               Tel. +49-4931-918175-31
> Dipl.-Inf. (FH)           Rheinstra?e 13            Fax. +49-4931-918175-50
> Software Engineer         D-26506 Norden
> http://www.norbit.de
> QGIS PSC member (RM)                                   IRC: jef on FreeNode
> norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
> Rheinstrasse 13, 26506 Norden
> GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
> Message: 8
> Date: Mon, 30 Sep 2013 19:15:17 +0200
> From: Antonio Vico <avicomartin at gmail.com>
> Subject: Re: [Qgis-user] Authentication in QGIS Server (WFS Service)
> Message-ID: <5249B1A5.2060804 at gmail.com>
> Hi all, and thanks for the replies.
> Maybe I am not explained correctly what I want.
> I don't want secure the acces to the qgis-web-client. I want secure the
> acces to the qgis wfs server when I connect to the map exported using
> qgis desktop.
> The situation is this:
> I can't acces directrly from qgis desktop (local) to postgresql database
> (remote) due the connexion conditions. For solve this, I create a qgis
> project (mymap.qgs) in the remote server that access directly to the
> database, and connect to this file with a wfs service (in my local qgis
> desktop I load a wfs layer from mymap.qgs with the data).
> This configuration increase the speed in connexion (load wfs remote
> layer is more fast than load remote postgres layer) but has the problem
> that someone can connect to the wfs server and edit the data. Is this
> wfs connection what I want protect.
> Now I am testing things about URL rewriting acconding comments from
> Andreas Newman.
> About Lizmap, I tested this web client time ago and I don't know if can
> do what I want. I will test :-)
> > Hash: SHA1
> > Il 29/09/2013 18:34, Antonio Vico ha scritto:
> >> I tested basic protection whit .htaccess file in the directory. This
> require
> >> user/password for access with a browser but defining a wfs server like
> >> http://my_host/cgi-bin/qgis_mapserv.fcgi?map=/var/www/Test01/mymap.qgsin qgis
> >> desktop can acces without restrictions to the map file.
> > NB: LizMap has an embedded mechanism for this, with a web GUI to
> administer permissions.
> > All the best.
> > Paolo Cavallini - Faunalia
> > www.faunalia.eu
> > Full contact details at www.faunalia.eu/pc
> > Nuovi corsi QGIS e PostGIS: http://www.faunalia.it/calendario
> > Version: GnuPG v1.4.14 (GNU/Linux)
> > Comment: Using GnuPG with Icedove - http://www.enigmail.net/
> > iEYEARECAAYFAlJJEuEACgkQ/NedwLUzIr7g7ACeIILL/5aIWYF43Qo3k+Gjc7vR
> > uB0AnAw2t4g2Rp7vKd4h+CfJqkrJIb0f
> > =V9XG
> Message: 9
> Date: Mon, 30 Sep 2013 19:23:32 +0200
> From: Paolo Cavallini <cavallini at faunalia.it>
> Message-ID: <5249B394.4080301 at faunalia.it>
> Hash: SHA1
> do what I
> I confirm that you can do it. Interesting: WFS faster than direct DB
> access.
> All the best.
> www.faunalia.eu
> iEYEARECAAYFAlJJs5MACgkQ/NedwLUzIr6p2gCggqZZxD6oSxNI60QYjDt2UT6T
> rLwAn22d6vZtU3RuLcS3MOjmUbsG4Dou
> =+0Et
> Message: 10
> Date: Mon, 30 Sep 2013 13:06:02 -0500
> From: Ra?l Nanclares <raulnanclares at gmail.com>
> Subject: [Qgis-user] Help reproducing a bug with Fix shapefile
>         Encoding Plugin and Openlayers plugin - W7 - QGIS 2.0.1
> Message-ID:
> CAO-Z3uPz9WT+AKeSJtwSAen8MGTEjXF+SQLiWBJvDfR+AxjVxw at mail.gmail.com>
> Hi everybody,
> i need somebody to confirm there's a bug in the Fix Shapefile Encofing
> Plugin.
> Steps to reproduce:
>    1. Add an openlayers layer using the plugin.
>    2. Add a shapefile.
>    3. Try changing the shapefile encoding using the pluging mentioned
> above.
>    4. Get python Error:
> An error has occured while executing Python code:
> Traceback (most recent call last):
>   File
> "C:\Users\user/.qgis2/python/plugins\shapefile_encoding_fixer\encoding_fixer_plugin.py",
> line 311, in runAndClose
>     self.run()
>   File
> line 321, in run
>     if self.layerSource( self.iface.mapCanvas().layer(i) ) ==
> self.shapefileName:
>   File
> line 200, in layerSource
>     srcPath = layer.dataProvider().dataSourceUri().split('|')[0]
> AttributeError: 'OpenlayersLayer' object has no attribute 'dataProvider'
> Python version:
> 2.7.4 (default, Apr  6 2013, 19:54:46) [MSC v.1500 32 bit (Intel)]
> QGIS version:
> 2.0.1-Dufour Dufour, 34139bc
> Thanks!
> URL: <
> http://lists.osgeo.org/pipermail/qgis-user/attachments/20130930/a7fc947e/attachment-0001.html
> Message: 11
> Date: Mon, 30 Sep 2013 20:34:24 +0200
> From: Goyo <goyodiaz at gmail.com>
> To: Ra?l Nanclares <raulnanclares at gmail.com>
> Cc: qgis-user <qgis-user at lists.osgeo.org>
> Subject: Re: [Qgis-user] Help reproducing a bug with Fix shapefile
> Message-ID:
>         <CACNjSPS9rzaccV7B3udoGCW=+
> PVu0HY0D6-07-GxmNrV1BD3Jw at mail.gmail.com>
> Content-Type: text/plain; charset=UTF-8
> 2013/9/30 Ra?l Nanclares <raulnanclares at gmail.com>:
> > Hi everybody,
> > Plugin.
> > Steps to reproduce:
> > Add a shapefile.
> > Try changing the shapefile encoding using the pluging mentioned above.
> > Get python Error:
> >   File
> >     self.run()
> >   File
> > line 321, in run
> > self.shapefileName:
> >   File
> I can replicate this in master.
> Goyo
> End of Qgis-user Digest, Vol 91, Issue 91
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130930/bbe13540/attachment.html>
