[Qgis-user] QGIS 2.2 Valmiera install problem- Shortcuts don't work
Matthew Parfitt Matthew.Parfitt at BuroHappold.com
Wed Apr 2 02:26:09 PDT 2014
Hello Saber,
Yes we have EndPoint. I'll check the quarantined items and let you know how that goes.
Regards,
Matthew Parfitt
How was my performance?  Let my manager know.
Please Feedback on our IT Service Performance (only 4 questions!).
-----Original Message-----
From: qgis-user-bounces at lists.osgeo.org [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Saber Razmjooei
Sent: 02 April 2014 10:19
To: QGIS Users List
Subject: Re: [Qgis-user] QGIS 2.2 Valmiera install problem- Shortcuts don't work
Hi Matthew,
You should be able to have both versions installed. Do you have any AV software installed by any chance? Sometimes it happens that anti-virus software removes *.exe files without making users aware of that.
Cheers,
Saber
_______________________________________________________________________________
 From: qgis-user-bounces at lists.osgeo.org [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Matthew Parfitt
Sent: 02 April 2014 09:56
To: qgis-user at lists.osgeo.org
Cc: Stephen Henry
Subject: [Qgis-user] QGIS 2.2 Valmiera install problem- Shortcuts don't work
Hello,
I have installed QGIS 2.2 Valmiera for my colleague Stephen. He was previously using QGIS 1.8 and still has the version installed.
I installed QGIS Standalone installer v2.2 (64Bit). The install went through with no problems but when we tried to open the program via
Start>all programs> QGIS Valmiera, nothing happens and the program does
not open.
Does having 2 versions installed cause problems like this?
Thanks in advance.
Matthew Parfitt
This transmission is confidential and intended solely for the person or
organisation to whom it is correctly addressed. If you are not the
intended recipient of this transmission, you should not take any action
in reliance on it. Further, this transmission may contain confidential
design and other information owned by Buro Happold Ltd. You should not
copy, distribute, use, offer for sale or hire such information or in any
way infringe the design and intellectual property rights of Buro Happold
Ltd. It is intended that communication by email from Buro Happold Ltd or
its employees is limited to communications connected to the services
provided by Buro Happold Ltd. Buro Happold Ltd accepts no liability for
any communications not connected to the services it provides. Computer
viruses may be transmitted or downloaded onto your computer system via
email communication. It is the recipient’s responsibility to take any
action necessary to prevent computer viruses being transmitted in this
way. Accordingly, Buro Happold Ltd disclaims all responsibility which
arises directly or indirectly from such transmission of computer
viruses. Buro Happold Ltd. Registered in England: 2049511
This email and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed.
If you have received this email in error please notify the system manager. This message contains confidential information and is intended only for the
individual named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail. Please notify the sender immediately
by e-mail if you have received this e-mail by mistake and delete this e-mail from your system. If you are not the intended recipient you are notified
that disclosing, copying, distributing or taking any action in reliance on the contents of this information is strictly prohibited.
Whilst reasonable care has been taken to avoid virus transmission, no responsibility for viruses is taken and it is your responsibility to carry out
such checks as you feel appropriate.
If this email contains a quote or offer to sell products, carry out work or perform services then our standard terms and conditions (which can be found at http://www.lutraconsulting.co.uk/downloads/Lutra%20Consulting%20Standard%20Terms%20and%20Conditions.pdf shall apply unless explicitly stated otherwise.
Saber Razmjooei and Peter Wells trading as Lutra Consulting.
Qgis-user mailing list
Qgis-user at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-user
