[Qgis-user] QGIS 2.2 Valmiera install problem- Shortcuts don't work
Saber Razmjooei
saber.razmjooei at lutraconsulting.co.uk
Wed Apr 2 02:33:52 PDT 2014
Hi Matt,
Check if you have the following file to start with:
C:\Programme Files\QGIS Valmiera\bin\qgis-bin.exe
Cheers,
Saber
On 2014-04-02 10:26, Matthew Parfitt wrote:
> Hello Saber,
> Yes we have EndPoint. I'll check the quarantined items and let you
> know how that goes.
> Regards,
> Matthew Parfitt
> How was my performance? Let my manager know.
> Please Feedback on our IT Service Performance (only 4 questions!).
> -----Original Message-----
> From: qgis-user-bounces at lists.osgeo.org
> [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Saber
> Razmjooei
> Sent: 02 April 2014 10:19
> To: QGIS Users List
> Subject: Re: [Qgis-user] QGIS 2.2 Valmiera install problem- Shortcuts
> don't work
> Hi Matthew,
> You should be able to have both versions installed. Do you have any
> AV software installed by any chance? Sometimes it happens that
> anti-virus software removes *.exe files without making users aware of
> that.
> Cheers,
> Saber
> _______________________________________________________________________________
> [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Matthew
> Parfitt
> Sent: 02 April 2014 09:56
> To: qgis-user at lists.osgeo.org
> Cc: Stephen Henry
> Subject: [Qgis-user] QGIS 2.2 Valmiera install problem- Shortcuts
> don't work
> Hello,
> I have installed QGIS 2.2 Valmiera for my colleague Stephen. He was
> previously using QGIS 1.8 and still has the version installed.
> I installed QGIS Standalone installer v2.2 (64Bit). The install went
> through with no problems but when we tried to open the program via
> Start>all programs> QGIS Valmiera, nothing happens and the program
> does
> not open.
> Does having 2 versions installed cause problems like this?
> Thanks in advance.
> Matthew Parfitt
> This transmission is confidential and intended solely for the person
> or
> organisation to whom it is correctly addressed. If you are not the
> intended recipient of this transmission, you should not take any
> action
> in reliance on it. Further, this transmission may contain
> confidential
> design and other information owned by Buro Happold Ltd. You should
> not
> copy, distribute, use, offer for sale or hire such information or in
> any
> way infringe the design and intellectual property rights of Buro
> Happold
> Ltd. It is intended that communication by email from Buro Happold Ltd
> or
> its employees is limited to communications connected to the services
> provided by Buro Happold Ltd. Buro Happold Ltd accepts no liability
> for
> any communications not connected to the services it provides.
> Computer
> viruses may be transmitted or downloaded onto your computer system
> via
> email communication. It is the recipient’s responsibility to take any
> action necessary to prevent computer viruses being transmitted in
> this
> way. Accordingly, Buro Happold Ltd disclaims all responsibility which
> arises directly or indirectly from such transmission of computer
> viruses. Buro Happold Ltd. Registered in England: 2049511
> This email and any files transmitted with it are confidential and
> intended solely for the use of the individual or entity to whom they
> are addressed.
> If you have received this email in error please notify the system
> manager. This message contains confidential information and is
> intended only for the
> individual named. If you are not the named addressee you should not
> disseminate, distribute or copy this e-mail. Please notify the sender
> immediately
> by e-mail if you have received this e-mail by mistake and delete this
> e-mail from your system. If you are not the intended recipient you
> are
> notified
> that disclosing, copying, distributing or taking any action in
> reliance on the contents of this information is strictly prohibited.
> Whilst reasonable care has been taken to avoid virus transmission, no
> responsibility for viruses is taken and it is your responsibility to
> carry out
> such checks as you feel appropriate.
> If this email contains a quote or offer to sell products, carry out
> work or perform services then our standard terms and conditions
> (which
> can be found at
> http://www.lutraconsulting.co.uk/downloads/Lutra%20Consulting%20Standard%20Terms%20and%20Conditions.pdf
> shall apply unless explicitly stated otherwise.
> Saber Razmjooei and Peter Wells trading as Lutra Consulting.
> Qgis-user mailing list
