[Qgis-user] QGIS 2.2 Valmiera install problem- Shortcuts don't work
Matthew Parfitt Matthew.Parfitt at BuroHappold.com
Wed Apr 2 02:49:28 PDT 2014
Hi Saber,
Yes we do have this .exe. When I run it an error message appears that reads:'The program can't start because qgis_core.dll is missing from your computer. Try reinstalling the programs to fix this problem.
We have re-installed a couple of times already.
Regards,
Matthew Parfitt
-----Original Message-----
From: qgis-user-bounces at lists.osgeo.org [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Saber Razmjooei
Sent: 02 April 2014 10:34
To: qgis-user at lists.osgeo.org
Subject: Re: [Qgis-user] QGIS 2.2 Valmiera install problem- Shortcuts don't work
Hi Matt,
Check if you have the following file to start with:
C:\Programme Files\QGIS Valmiera\bin\qgis-bin.exe
Cheers,
Saber
On 2014-04-02 10:26, Matthew Parfitt wrote:
> Hello Saber,
> Yes we have EndPoint. I'll check the quarantined items and let you
> know how that goes.
> Regards,
> Matthew Parfitt
> How was my performance?  Let my manager know.
> Please Feedback on our IT Service Performance (only 4 questions!).
> Razmjooei
> Sent: 02 April 2014 10:19
> To: QGIS Users List
> don't work
> Hi Matthew,
> You should be able to have both versions installed. Do you have any AV
> software installed by any chance? Sometimes it happens that anti-virus
> software removes *.exe files without making users aware of that.
> Cheers,
> Saber
> ______________________________________________________________________
> _________
> [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Matthew
> Parfitt
> Sent: 02 April 2014 09:56
> Cc: Stephen Henry
> Subject: [Qgis-user] QGIS 2.2 Valmiera install problem- Shortcuts
> don't work
> Hello,
> I have installed QGIS 2.2 Valmiera for my colleague Stephen. He was
> previously using QGIS 1.8 and still has the version installed.
> I installed QGIS Standalone installer v2.2 (64Bit). The install went
> through with no problems but when we tried to open the program via
> Start>all programs> QGIS Valmiera, nothing happens and the program
> does
> not open.
> Does having 2 versions installed cause problems like this?
> Thanks in advance.
> Matthew Parfitt
> This transmission is confidential and intended solely for the person
> or organisation to whom it is correctly addressed. If you are not the
> intended recipient of this transmission, you should not take any
> action in reliance on it. Further, this transmission may contain
> confidential design and other information owned by Buro Happold Ltd.
> You should not copy, distribute, use, offer for sale or hire such
> information or in any way infringe the design and intellectual
> property rights of Buro Happold Ltd. It is intended that communication
> by email from Buro Happold Ltd or its employees is limited to
> communications connected to the services provided by Buro Happold Ltd.
> Buro Happold Ltd accepts no liability for any communications not
> connected to the services it provides.
> Computer
> viruses may be transmitted or downloaded onto your computer system via
> email communication. It is the recipient’s responsibility to take any
> action necessary to prevent computer viruses being transmitted in this
> way. Accordingly, Buro Happold Ltd disclaims all responsibility which
> arises directly or indirectly from such transmission of computer
> viruses. Buro Happold Ltd. Registered in England: 2049511
> This email and any files transmitted with it are confidential and
> intended solely for the use of the individual or entity to whom they
> are addressed.
> If you have received this email in error please notify the system
> manager. This message contains confidential information and is
> intended only for the individual named. If you are not the named
> addressee you should not disseminate, distribute or copy this e-mail.
> Please notify the sender immediately by e-mail if you have received
> this e-mail by mistake and delete this e-mail from your system. If you
> are not the intended recipient you are notified that disclosing,
> copying, distributing or taking any action in reliance on the contents
> of this information is strictly prohibited.
> Whilst reasonable care has been taken to avoid virus transmission, no
> responsibility for viruses is taken and it is your responsibility to
> carry out such checks as you feel appropriate.
> If this email contains a quote or offer to sell products, carry out
> work or perform services then our standard terms and conditions (which
> can be found at
> http://www.lutraconsulting.co.uk/downloads/Lutra%20Consulting%20Standa
> rd%20Terms%20and%20Conditions.pdf shall apply unless explicitly stated
> otherwise.
> Saber Razmjooei and Peter Wells trading as Lutra Consulting.
> Qgis-user mailing list
