[Qgis-user] QGIS 2.2 Valmiera install problem- Shortcuts don't work
Saber Razmjooei
saber.razmjooei at lutraconsulting.co.uk
Wed Apr 2 02:52:43 PDT 2014
Hi Matt,
You need to run the .bat file on your desktop or start menu.
Cheers,
Saber
On 2014-04-02 10:49, Matthew Parfitt wrote:
> Hi Saber,
> Yes we do have this .exe. When I run it an error message appears that
> reads:'The program can't start because qgis_core.dll is missing from
> your computer. Try reinstalling the programs to fix this problem.
> We have re-installed a couple of times already.
> Regards,
> Matthew Parfitt
> -----Original Message-----
> From: qgis-user-bounces at lists.osgeo.org
> [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Saber
> Razmjooei
> Sent: 02 April 2014 10:34
> To: qgis-user at lists.osgeo.org
> Subject: Re: [Qgis-user] QGIS 2.2 Valmiera install problem- Shortcuts
> don't work
> Hi Matt,
> Check if you have the following file to start with:
> C:\Programme Files\QGIS Valmiera\bin\qgis-bin.exe
> Cheers,
> Saber
> On 2014-04-02 10:26, Matthew Parfitt wrote:
>> Hello Saber,
>> Yes we have EndPoint. I'll check the quarantined items and let you
>> know how that goes.
>> Regards,
>> Matthew Parfitt
>> How was my performance? Let my manager know.
>> Please Feedback on our IT Service Performance (only 4 questions!).
>> Razmjooei
>> Sent: 02 April 2014 10:19
>> To: QGIS Users List
>> Shortcuts
>> don't work
>> Hi Matthew,
>> You should be able to have both versions installed. Do you have any
>> AV
>> software installed by any chance? Sometimes it happens that
>> anti-virus
>> software removes *.exe files without making users aware of that.
>> Cheers,
>> Saber
>> ______________________________________________________________________
>> _________
>> [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Matthew
>> Parfitt
>> Sent: 02 April 2014 09:56
>> Cc: Stephen Henry
>> Subject: [Qgis-user] QGIS 2.2 Valmiera install problem- Shortcuts
>> don't work
>> Hello,
>> I have installed QGIS 2.2 Valmiera for my colleague Stephen. He was
>> previously using QGIS 1.8 and still has the version installed.
>> I installed QGIS Standalone installer v2.2 (64Bit). The install went
>> through with no problems but when we tried to open the program via
>> Start>all programs> QGIS Valmiera, nothing happens and the program
>> does
>> not open.
>> Does having 2 versions installed cause problems like this?
>> Thanks in advance.
>> Matthew Parfitt
>> This transmission is confidential and intended solely for the person
>> or organisation to whom it is correctly addressed. If you are not
>> the
>> intended recipient of this transmission, you should not take any
>> action in reliance on it. Further, this transmission may contain
>> confidential design and other information owned by Buro Happold Ltd.
>> You should not copy, distribute, use, offer for sale or hire such
>> information or in any way infringe the design and intellectual
>> property rights of Buro Happold Ltd. It is intended that
>> communication
>> by email from Buro Happold Ltd or its employees is limited to
>> communications connected to the services provided by Buro Happold
>> Ltd.
>> Buro Happold Ltd accepts no liability for any communications not
>> connected to the services it provides.
>> Computer
>> viruses may be transmitted or downloaded onto your computer system
>> via
>> email communication. It is the recipient’s responsibility to take
>> any
>> action necessary to prevent computer viruses being transmitted in
>> this
>> way. Accordingly, Buro Happold Ltd disclaims all responsibility
>> which
>> arises directly or indirectly from such transmission of computer
>> viruses. Buro Happold Ltd. Registered in England: 2049511
>> This email and any files transmitted with it are confidential and
>> intended solely for the use of the individual or entity to whom they
>> are addressed.
>> If you have received this email in error please notify the system
>> manager. This message contains confidential information and is
>> intended only for the individual named. If you are not the named
>> addressee you should not disseminate, distribute or copy this
>> e-mail.
>> Please notify the sender immediately by e-mail if you have received
>> this e-mail by mistake and delete this e-mail from your system. If
>> you
>> are not the intended recipient you are notified that disclosing,
>> copying, distributing or taking any action in reliance on the
>> contents
>> of this information is strictly prohibited.
>> Whilst reasonable care has been taken to avoid virus transmission,
>> no
>> responsibility for viruses is taken and it is your responsibility to
>> carry out such checks as you feel appropriate.
>> If this email contains a quote or offer to sell products, carry out
>> work or perform services then our standard terms and conditions
>> (which
>> can be found at
>> http://www.lutraconsulting.co.uk/downloads/Lutra%20Consulting%20Standa
>> rd%20Terms%20and%20Conditions.pdf shall apply unless explicitly
>> stated
>> otherwise.
>> Saber Razmjooei and Peter Wells trading as Lutra Consulting.
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
