[Qgis-user] QGIS 2.2 Valmiera install problem- Shortcuts don't work
Ramon Andiñach custard at westnet.com.au
Wed Apr 2 06:54:00 PDT 2014
Oh, I thought the bat file was in the same directory as the .exe
The Desktop and Start Menu icons are just shortcuts to that.
-ramon.
On 02/04/2014, at 17:52 , Saber Razmjooei wrote:
> Hi Matt,
> You need to run the .bat file on your desktop or start menu.
> Cheers,
> Saber
> On 2014-04-02 10:49, Matthew Parfitt wrote:
>> Hi Saber,
>> Yes we do have this .exe. When I run it an error message appears that
>> reads:'The program can't start because qgis_core.dll is missing from
>> your computer. Try reinstalling the programs to fix this problem.
>> We have re-installed a couple of times already.
>> Regards,
>> Matthew Parfitt
>> -----Original Message-----
>> From: qgis-user-bounces at lists.osgeo.org
>> [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Saber
>> Razmjooei
>> Sent: 02 April 2014 10:34
>> To: qgis-user at lists.osgeo.org
>> Subject: Re: [Qgis-user] QGIS 2.2 Valmiera install problem- Shortcuts
>> don't work
>> Hi Matt,
>> Check if you have the following file to start with:
>> C:\Programme Files\QGIS Valmiera\bin\qgis-bin.exe
>> Cheers,
>> Saber
>> On 2014-04-02 10:26, Matthew Parfitt wrote:
>>> Hello Saber,
>>> Yes we have EndPoint. I'll check the quarantined items and let you
>>> know how that goes.
>>> Regards,
>>> Matthew Parfitt
>>> How was my performance?  Let my manager know.
>>> Please Feedback on our IT Service Performance (only 4 questions!).
>>> Razmjooei
>>> Sent: 02 April 2014 10:19
>>> To: QGIS Users List
>>> don't work
>>> Hi Matthew,
>>> You should be able to have both versions installed. Do you have any AV
>>> software installed by any chance? Sometimes it happens that anti-virus
>>> software removes *.exe files without making users aware of that.
>>> Cheers,
>>> Saber
>>> ______________________________________________________________________
>>> _________
>>> [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Matthew
>>> Parfitt
>>> Sent: 02 April 2014 09:56
>>> Cc: Stephen Henry
>>> Subject: [Qgis-user] QGIS 2.2 Valmiera install problem- Shortcuts
>>> don't work
>>> Hello,
>>> I have installed QGIS 2.2 Valmiera for my colleague Stephen. He was
>>> previously using QGIS 1.8 and still has the version installed.
>>> I installed QGIS Standalone installer v2.2 (64Bit). The install went
>>> through with no problems but when we tried to open the program via
>>> Start>all programs> QGIS Valmiera, nothing happens and the program
>>> does
>>> not open.
>>> Does having 2 versions installed cause problems like this?
>>> Thanks in advance.
>>> Matthew Parfitt
>>> This transmission is confidential and intended solely for the person
>>> or organisation to whom it is correctly addressed. If you are not the
>>> intended recipient of this transmission, you should not take any
>>> action in reliance on it. Further, this transmission may contain
>>> confidential design and other information owned by Buro Happold Ltd.
>>> You should not copy, distribute, use, offer for sale or hire such
>>> information or in any way infringe the design and intellectual
>>> property rights of Buro Happold Ltd. It is intended that communication
>>> by email from Buro Happold Ltd or its employees is limited to
>>> communications connected to the services provided by Buro Happold Ltd.
>>> Buro Happold Ltd accepts no liability for any communications not
>>> connected to the services it provides.
>>> Computer
>>> viruses may be transmitted or downloaded onto your computer system via
>>> email communication. It is the recipient’s responsibility to take any
>>> action necessary to prevent computer viruses being transmitted in this
>>> way. Accordingly, Buro Happold Ltd disclaims all responsibility which
>>> arises directly or indirectly from such transmission of computer
>>> viruses. Buro Happold Ltd. Registered in England: 2049511
>>> This email and any files transmitted with it are confidential and
>>> intended solely for the use of the individual or entity to whom they
>>> are addressed.
>>> If you have received this email in error please notify the system
>>> manager. This message contains confidential information and is
>>> intended only for the individual named. If you are not the named
>>> addressee you should not disseminate, distribute or copy this e-mail.
>>> Please notify the sender immediately by e-mail if you have received
>>> this e-mail by mistake and delete this e-mail from your system. If you
>>> are not the intended recipient you are notified that disclosing,
>>> copying, distributing or taking any action in reliance on the contents
>>> of this information is strictly prohibited.
>>> Whilst reasonable care has been taken to avoid virus transmission, no
>>> responsibility for viruses is taken and it is your responsibility to
>>> carry out such checks as you feel appropriate.
>>> If this email contains a quote or offer to sell products, carry out
>>> work or perform services then our standard terms and conditions (which
>>> can be found at
>>> http://www.lutraconsulting.co.uk/downloads/Lutra%20Consulting%20Standa
>>> rd%20Terms%20and%20Conditions.pdf shall apply unless explicitly stated
>>> otherwise.
>>> Saber Razmjooei and Peter Wells trading as Lutra Consulting.
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
