[Qgis-user] OpenStreetMap in QGIS
Ross McDonald ross at mixedbredie.net
Wed Apr 2 13:42:00 PDT 2014
Hi Jonathan,
You could use the OSM GB WMS to bring in tiles in EPSG:27700 if need be.
Get it here: http://www.osmgb.org.uk/osm-gb-wiki/index.php/WMS and add
it as a new WMS source.
Cheers
Ross
On 02/04/14 12:34, Saber Razmjooei wrote:
> Hi Jonathan,
> See the following tickets for problem with the OpenLayers plugin and
> QGIS Master:
> http://hub.qgis.org/issues/9626
>  http://hub.qgis.org/issues/9649
> Meanwhile, you probably  can download the relevant tiles and style them,
> which is not very convenient!
> Cheers,
> Saber
> *From:*qgis-user-bounces at lists.osgeo.org
> [mailto:qgis-user-bounces at lists.osgeo.org] *On Behalf Of *Jonathan Moules
> *Sent:* 02 April 2014 12:27
> *To:* qgis-user at lists.osgeo.org
> *Subject:* [Qgis-user] OpenStreetMap in QGIS
> Hi List,
> So, I know that QGIS is supposed to integrate nicely with OSM, however
> I'm trying to use the "OpenLayers Plugin" 1.1.2 but it seems prone to
> crashing QGIS (2.3 - nightly snapshot) and never actually loads any of
> the mapping.
> So how do I get OSM as a baselayer in QGIS? Or is this the proper way
> but I'm just unlucky?
> Cheers,
> Jonathan
> This transmission is intended for the named addressee(s) only and may
> contain sensitive or protectively marked material up to RESTRICTED and
> should be handled accordingly. Unless you are the named addressee (or
> authorised to receive it for the addressee) you may not copy or use it,
> or disclose it to anyone else. If you have received this transmission in
> error please notify the sender immediately. All email traffic sent to or
> from us, including without limitation all GCSX traffic, may be subject
> to recording and/or monitoring in accordance with relevant legislation.
> This email and any files transmitted with it are confidential and
> intended solely for the use of the individual or entity to whom they are
> addressed. If you have received this email in error please notify the
> system manager. This message contains confidential information and is
> intended only for the individual named. If you are not the named
> addressee you should not disseminate, distribute or copy this e-mail.
> Please notify the sender immediately by e-mail if you have received this
> e-mail by mistake and delete this e-mail from your system. If you are
> not the intended recipient you are notified that disclosing, copying,
> distributing or taking any action in reliance on the contents of this
> information is strictly prohibited.
> Whilst reasonable care has been taken to avoid virus transmission, no
> responsibility for viruses is taken and it is your responsibility to
> carry out such checks as you feel appropriate.
> If this email contains a quote or offer to sell products, carry out work
> or perform services then our standard terms and conditions
> <http://www.lutraconsulting.co.uk/downloads/Lutra%20Consulting%20Standard%20Terms%20and%20Conditions.pdf>
> shall apply unless explicitly stated otherwise.
> Saber Razmjooei and Peter Wells trading as Lutra Consulting.
> Qgis-user mailing list
