[Qgis-user] OpenStreetMap in QGIS
Yasser Said Lopez de Olmos Reyes biolyasser at gmail.com
Fri Apr 4 10:17:41 PDT 2014
Another way could be as a TMS. Use this code and save it as a XML file.
>From QGIS  add as a Raster layer:
<GDAL_WMS>
    <Service name="TMS">
        <ServerUrl>http://tile.openstreetmap.org/${z}/${x}/${y}.png</ServerUrl>
    </Service>
    <DataWindow>
        <UpperLeftX>-20037508.34</UpperLeftX>
        <UpperLeftY>20037508.34</UpperLeftY>
        <LowerRightX>20037508.34</LowerRightX>
        <LowerRightY>-20037508.34</LowerRightY>
        <TileLevel>18</TileLevel>
        <TileCountX>1</TileCountX>
        <TileCountY>1</TileCountY>
        <YOrigin>top</YOrigin>
    </DataWindow>
    <Projection>EPSG:900913</Projection>
    <BlockSizeX>256</BlockSizeX>
    <BlockSizeY>256</BlockSizeY>
    <BandsCount>3</BandsCount>
    <Cache />
</GDAL_WMS>
This code was taken from
http://www.3liz.com/blog/rldhont/index.php?post/2012/07/17/OpenStreetMap-Tiles-in-QGIS,
so maybe you should take a look at this source.
The time I tried it worked well, just be careful with projections as always.
2014-04-02 14:42 GMT-06:00 Ross McDonald <ross at mixedbredie.net>:
> Hi Jonathan,
> You could use the OSM GB WMS to bring in tiles in EPSG:27700 if need be.
> Get it here: http://www.osmgb.org.uk/osm-gb-wiki/index.php/WMS and add
> it as a new WMS source.
> Cheers
> Ross
> On 02/04/14 12:34, Saber Razmjooei wrote:
> > Hi Jonathan,
> > See the following tickets for problem with the OpenLayers plugin and
> > QGIS Master:
> > http://hub.qgis.org/issues/9626
> >  http://hub.qgis.org/issues/9649
> > Meanwhile, you probably  can download the relevant tiles and style them,
> > which is not very convenient!
> > Cheers,
> > Saber
> > *From:*qgis-user-bounces at lists.osgeo.org
> > [mailto:qgis-user-bounces at lists.osgeo.org] *On Behalf Of *Jonathan
> Moules
> > *Sent:* 02 April 2014 12:27
> > *To:* qgis-user at lists.osgeo.org
> > *Subject:* [Qgis-user] OpenStreetMap in QGIS
> > Hi List,
> > So, I know that QGIS is supposed to integrate nicely with OSM, however
> > I'm trying to use the "OpenLayers Plugin" 1.1.2 but it seems prone to
> > crashing QGIS (2.3 - nightly snapshot) and never actually loads any of
> > the mapping.
> > So how do I get OSM as a baselayer in QGIS? Or is this the proper way
> > but I'm just unlucky?
> > Cheers,
> > Jonathan
> > This transmission is intended for the named addressee(s) only and may
> > contain sensitive or protectively marked material up to RESTRICTED and
> > should be handled accordingly. Unless you are the named addressee (or
> > authorised to receive it for the addressee) you may not copy or use it,
> > or disclose it to anyone else. If you have received this transmission in
> > error please notify the sender immediately. All email traffic sent to or
> > from us, including without limitation all GCSX traffic, may be subject
> > to recording and/or monitoring in accordance with relevant legislation.
> > This email and any files transmitted with it are confidential and
> > intended solely for the use of the individual or entity to whom they are
> > addressed. If you have received this email in error please notify the
> > system manager. This message contains confidential information and is
> > intended only for the individual named. If you are not the named
> > addressee you should not disseminate, distribute or copy this e-mail.
> > Please notify the sender immediately by e-mail if you have received this
> > e-mail by mistake and delete this e-mail from your system. If you are
> > not the intended recipient you are notified that disclosing, copying,
> > distributing or taking any action in reliance on the contents of this
> > information is strictly prohibited.
> > Whilst reasonable care has been taken to avoid virus transmission, no
> > responsibility for viruses is taken and it is your responsibility to
> > carry out such checks as you feel appropriate.
> > If this email contains a quote or offer to sell products, carry out work
> > or perform services then our standard terms and conditions
> http://www.lutraconsulting.co.uk/downloads/Lutra%20Consulting%20Standard%20Terms%20and%20Conditions.pdf
> > shall apply unless explicitly stated otherwise.
> > Saber Razmjooei and Peter Wells trading as Lutra Consulting.
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-user
Saludos,
Yasser
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140404/8b367a7d/attachment.html>
