[Qgis-user] Tablet vs GPS accuracy
Zoltan Szecsei
zoltans at geograph.co.za
Thu Apr 3 10:44:53 PDT 2014
On 2014/04/03 17:09, Richard McDonnell wrote:
> The issue with phones and tablets is that, unlike dedicated systems,
> you have less control over how the coordinates are recorded. They
> don't take into account things like multipath (GPS signal bouncing off
> buildings, Ground etc.) The number of satellites (the more the
> better) Most survey kits wont record a point with less than 5 satellites.
and
> There is a way to get an idea of the accuracy for your proposed
> device. Take several readings over a day (7 or more) of 2 fixed points
> approx 50m apart, every day, for a week. Then compare the results.
> you will have a spread of points, none of which are likely to be
> perfect, but will give you an idea of the accuracies of the device,
> the spread of the points being your expected error. A shorter test
> over a day would yield similar results but over a week, you would have
> a more comprehensive result. I have seen some tests, where accuracies
> with an i-Phone were stated as +-3m.
Surely this test is not relevant in any way, as when he is in "the
field" (which could be a city centre), the accuracies would vary from
his test site.
The importance of such test is however that it makes the user _fully_
aware that the coords on the screen are not necessarily the position the
GPS receiver IS actually at (at that time).
People often seem to forget that a GPS screen is exactly like a TV
screen - what you see on it is not necessarily the truth :-)
Zoltan Szecsei PrGISc [PGP0031]
Geograph (Pty) Ltd.
GIS and Photogrammetric Services
P.O. Box 7, Muizenberg 7950, South Africa.
Mobile: +27-83-6004028
Fax: +27-86-6115323 www.geograph.co.za
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140403/81f043e7/attachment.html>
