[Qgis-user] Tablet vs GPS accuracy
Bo Victor Thomsen bo.victor.thomsen at gmail.com
Fri Apr 4 01:32:13 PDT 2014
If you are working with tablets and an external GPS connected to the
tablet using USB or Bluetooth, you should have a look at some of the new
"GNSS mouse" type GNSS - receivers that support both both GPS and
GLONASS. The are significantly more accurate and positionally stable
than the GPS only types (in the same price range).
I have used a HOLUX M-215+ (remember the "+" - it means GLONASS
compatibility) and have a accuracy around 1 meter in the open land most
of the time.
The HOLUX unit cost around 60 Euros.
Regards
Bo Victor Thomsen
Aestas-GIS
Denmark
Den 04-04-2014 04:32, Leo Kris Palao skrev:
> Hi Guys,
> Thanks all for your valuable insights about my inquiry. I really
> appreciate your comments. I can use your comments as reference on how
> we will also evaluate GIS applications in Tablets.
> Our application mainly falls on agriculture. We want to use the
> tablets for surveying in Rural areas. And we want to use QGIS android
> so we can load our shapefile and raster maps for validation. On the
> other hand, we will also want to use tablets to take location of field
> corners of farmers field to get the plot size (this is where accuracy
> is important).
> I observe that when there is a wifi the location significantly
> increases in tablets. But of course, wifi is not available in rural
> areas. So, if we will use tablet we will just rely on available GPS
> signal, weather, and the device.
> Thank so much, and again I really appreciate the comments,
> -Leo
> On Fri, Apr 4, 2014 at 2:20 AM, Michael.Dodd <Michael.Dodd at open.ac.uk
> <mailto:Michael.Dodd at open.ac.uk>> wrote:
>     I agree with the points Richard has made here.  I mentioned in an
>     earlier message on this topic that I'd done a lot of testing with
>     smartphones vs consumer gps  see
>     http://www.open.ac.uk/blogs/otih/?p=466 for details on some of the
>     tests.
>     Also tested consumer grade gps and a range of other surveying
>     techniques with results and discussion shown here:
>     http://oro.open.ac.uk/30066/
>     ________________________________________
>     From: Richard McDonnell [richard.mcdonnell at opw.ie
>     <mailto:richard.mcdonnell at opw.ie>]
>     Sent: Thursday, April 03, 2014 4:09 PM
>     To: Leo Kris Palao
>     Cc: QGIS Mailing List
>     Subject: Re: [Qgis-user] Tablet vs GPS accuracy
>     Hi,
>     It all boils down to the level of accuracy your job requires,
>     Commercial or Survey Grade GNSS (Global Navigation Satellite
>     System) now utilises NRTK (Network Real Time Kinematic) which can
>     produce sub centimetre accuracies. We have found that the
>     accuracies is often too good, with our surveys conflicting with
>     Maps. We have seen +-40mm accuracies in the field, where a stake
>     in the ground is surveyed and the kit can take us right back to
>     the point days later, to within 40mm. it is worth noting that
>     Survey grade GPS has a stated accuracy of sub meter without NRTK.
>     The next step down in accuracies would be GPS enabled Field
>     Computers, again a dedicated kit but hand held form factor, the
>     Trimble Geo-Explorer 7 is an example of one of these. They now
>     also have the ability to utilise NRTK, bringing there accuracies
>     to within 0.5m (or better).
>     The issue with phones and tablets is that, unlike dedicated
>     systems, you have less control over how the coordinates are
>     recorded. They don't take into account things like multipath (GPS
>     signal bouncing off buildings, Ground etc.)  The number of
>     satellites (the more the better) Most survey kits wont record a
>     point with less than 5 satellites.
>     There is a way to get an idea of the accuracy for your proposed
>     device. Take several readings over a day (7 or more) of 2 fixed
>     points approx 50m apart,  every day, for a week. Then compare the
>     results. you will have a spread of points, none of which are
>     likely to be perfect, but will give you an idea of the accuracies
>     of the device, the spread of the points being your expected error.
>     A shorter test over a day would yield similar results but over a
>     week, you would have a more comprehensive result. I have seen some
>     tests, where accuracies with an i-Phone were stated as +-3m.
>     One other thing you should all note when using a phone or similar
>     device to record your location, Use the native Latitude and
>     Longitude to record the position, don't use the device to
>     transform the coordinates to some other CRS. Use a dedicated CRS
>     Transformation tool on a desktop/Laptop computer to convert to
>     your desired CRS. Handhelds are not suitable for that purpose.
>     I hope this helps!!
>     Regards,
>     Richard.
>     On 03/04/2014 12:30, Leo Kris Palao wrote:
>     Hi QGIS Users,
>     I would like to inquire if there are some user that already
>     assessed the positioning (location) accuracy of tablet vs
>     commercial gps. We would like to use qgis android for fieldwork.
>     We would also like to try qmap.
>     Thanks,
>     Leo
>     _______________________________________________
>     Qgis-user mailing list
>     Qgis-user at lists.osgeo.org
>     <mailto:Qgis-user at lists.osgeo.org><mailto:Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>>
>     http://lists.osgeo.org/mailman/listinfo/qgis-user
>     Email Disclaimer: http://www.opw.ie/en/disclaimer/
>     -- The Open University is incorporated by Royal Charter (RC
>     000391), an exempt charity in England & Wales and a charity
>     registered in Scotland (SC 038302).
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140404/2df78d06/attachment.html>
