[Qgis-user] How can I assign an attribute of a layer to another layer - (I mean auto fill attibute of a layer if it contains in another layer)
Leknín Řepánek godzilalalala at gmail.com
Fri Apr 4 05:38:26 PDT 2014
Problem of this kind of task is fact, that you can have more values that
one in layer with values in destination polygon.
Maybe is an simple way in vector toolbox, or you can create intersection
of this two layers and update field in destination from intersect.
Je;
On Fri, Apr 04, 2014 at 08:28:45PM +0800, AJAY KUMAR MULAKALA wrote:
> Dear all
> I have a Point layer (fire stations and attributed with phone nos., colony
> name) and Polygon (Localities/Cities attributed with PIN/ZIP no.)
> I would now like to assign polygon file attributes (PIN/ZIP no) to point file
> attribute (locality- an existing empty column (or) a new column) where the
> point is containing in the polygon.
> if city/locality (polygon) consist with a fire station (point), then that city
> PIN/ZIP code is to add/assign to New/Existing column of fire station...?
> Regards
> AJAY
> Qgis-user mailing list
